Sirius Dock Base Mount  Kt-sr2000 Kt-sr3000 Logo
A
Anonymous Posted on Jul 22, 2011
How to change broadcast frequency when a strong local station interferes with sirius broadcast and reception on car FM radio. I have the SLV2 car dock for Stilleto Sirius receiver
Anonymous
Level 3:
  • Master 910 Answers
  • Posted on Jul 23, 2011
Anonymous
Master
Level 3:
Answers
910
Questions
Helped
306733
Points
2616
Page 32/33 othe PDF Manual at the link below details how to change the frequency.
http://audiovox2.info/docs/common/SLV2/SLV2_OM.pdf
  • Anonymous Jul 24, 2011
    Could you please advise what was wong with this solution for you to request a refund?
Pyle PBMSPG190 can't scan fm stations
If you're having trouble scanning FM radio stations on your Pyle PBMSPG190, there are a few things you can try:
- Check your antenna: Make sure your FM antenna is properly connected to your radio and is positioned in a location with good reception. If your antenna is damaged, you may need to replace it.
- Check the FM frequency range: Make sure that the FM frequency range of your radio is set correctly for your location. In some cases, FM frequencies may differ depending on your country or region.
- Check for interference: Electronic devices such as smartphones, tablets, or other nearby radios may cause interference with your radio's ability to pick up FM stations. Try turning off nearby electronics or moving your radio to a different location to see if this improves reception.
- Manually tune to specific frequencies: If the automatic scan is not working, try manually tuning your radio to specific FM frequencies to see if you can pick up any stations.
If none of these steps work, it's possible that there may be a problem with the radio's internal components. In that case, you may want to contact Pyle customer support for further assistance.
2003 grand marquis radio am does not work
Does anyone broadcast AM radio any more?
If you know you have a good AM station in your area, and you can verify its frequency, and your radio can't receive it but CAN receive FM stations... then that radio just isn't going to get AM. It's probably not worth fixing.
Low hum on one radio preset on Beosystem 2500
local interference find another frequency for classic fm there are lots
How to change fm seting on model ucb. I am traveling and have been plagued with local stations on 88.1
menu settings, tm channels. in there you select the frequency you want then hit select. then tune your stereo.
the only problem you will have is that as you travel you will end up having a station on any channel you are on. you will have to switch it a lot. there are 2 things you can do. 1 you can get an adapter that plugs from the sirius to the antenna port on the radion and then the cars.antenna in that. when sirius is on it bypassed the antenna on the car and pipes the signal right into the radio. or2 you can do what I did. I do not use am or tm so I completely disconnected the antenna.so I get no fm interference at all.
We installed a sirius satellite receiver to a tuner in a furniture store. We were so excited to be able to listen to something other than the same songs on our iPod playlist. We placed the antennae in a...
1st. use the signal strength meter found in the menu on the sirius streamer and then find the best position for your antenna, also fyi it depends where you are located in the us , i am in ks and my best direction is on the north side of my house. there may be interference from a strong station on an adjacent channel also .if you are using the fm broadcast feature of your streamer just try to use a frequency that doesn't have a signal on the next frequency to the one that you are using.
Just bought a car and it had hardwired sirius radio already installed. I called and activated it with Sirius radio and tried to get assistance from them on how to get it to work. They gave me instruction...
The "hard wired" version that you speak of apparently only refers to the power supply.Do you have a seperate display for the Sirius unit? Now, you failed to mention the type of radio (factory or aftermarket); so, if you have to use an "empty radio station" then you have an FM modulator. This modulator could wired or wireless. The wired version interrupts the vehicle antenna wire and the station on said modulator is usually preset to either 88.1, 88.3,88.7, or 89.1. There is no need to power this modulator up, it comes on when then Sirius comes on. One way to check for power is to turn on the Sirius unit and tune your radio to an occupied Fm station. Wait a few seconds and listen to the reception. Turn off the Sirius unit, the reception should improve for the occupied station. If it is a wireless FM modulator it also has preset stations that you can change but, extending the wieless antenna will greatly improve your reception of the Sirius stations.
Pioneer premier deh-500ub presetting stations
Storing the strongest broadcast
frequencies
BSM (best stations memory) lets you automatically
store the six strongest broadcast frequencies.
1 Use MULTI-CONTROL to select BSM in
the function menu.
2 Press MULTI-CONTROL to turn BSM on.
The six strongest broadcast frequencies are
stored in the order of their signal strength.
# To cancel, press MULTI-CONTROL again.
Tuning in strong signals
Local seek tuning lets you tune in only those
radio stations with sufficiently strong signals
for good reception.
% Press LOCAL repeatedly to select the
desired setting.
FM: OFF—LEVEL1—LEVEL2—LEVEL3—
LEVEL4
MW/LW: OFF—LEVEL1—LEVEL2
The LEVEL4 setting allows reception of only
the strongest stations, while lower settings let
you receive progressively weaker stations.
You can also perform this operation in the menu
that appears by using MULTI-CONTROL.
Selecting alternative frequencies
When the tuner cannot get a good reception,
the unit automatically searches for a different
station in the same network.
1 Use MULTI-CONTROL to select AF in the
function menu.
2 Press MULTI-CONTROL to turn AF on.
# To turn off, press MULTI-CONTROL again.
! Only RDS stations are tuned in during seek
tuning or BSM when AF is on.
! When you recall a preset station, the tuner
may update the preset station with a new frequency
from the station’s AF list. No preset
number appears on the display if the RDS
data for the station received differs from that
of the originally stored station.
! During AF search, sound may be temporarily
interrupted.
! AF can be turned on or off independently for
each FM band.
Pioneer GEX-FM903XM, system works great, however it often drops out and has just static. The signal indicator is strong. I think there is a bad connection into the radio. Where should I start...
It may be possible that the FM frequency chosen during setup, is in use in your area by a strong signal from a local station. Change to another frequency and see if the situation improves.
The following is from the Operation's Manual:
FM Modulator Setting
You can adjust FM Modulator frequency and output level.
7 Frequency
If output from the FM Modulator is hard to hear due to interference from a strong broadcast
station transmission, you can switch to another frequency.
You can adjust frequency between 87.9 and 90.1MHz.
7 Level
If the output sound is too quiet, too loud or distorted, you can adjust FM Modulator output
level.
You can adjust level between “LEVEL–1” and “LEVEL–7”.
1. Press the POWER button for 2 seconds to enter the FM Modulator Setting
mode.
2. Select the desired frequency
with the left/right arrow buttons.
3. Increase or decrease the Level
with the up/down arrows (buttons).
4. To cancel the FM Modulator Setting mode, press the POWER button again
for 2 seconds.
Note:
• After entering the FM Modulator Setting mode, if you do not perform an operation within about 8 seconds, the FM Modulator Setting is automatically canceled.
Radio static only but meta data displays
There will be static. A lot of my passengers are surprised that there is static on satellite radio, but there is. Your Sirius satellite receiver "broadcasts" to your car's FM radio through a frequency you select. For example, the Sirius channel on my car radio is 89.1, which is pretty clear and works pretty well on my regular commute. But if I drive beyond that route, where 89.1 is routinely used by regular broadcast radio stations, there is a lot of interference and static. I then have to switch frequencies on both the receiver and car radio, to find another clear channel. Quite a pain. There will be interference. Even the smallest bridge, tunnel, or parking garage often seems to block satellite reception, and occasionally the signal will completely disappear for no reason.
I DID TONS OF RESEARCH FOR YOU ABOUT THESE RADIOS. THE SAME PROBLEM YOU HAVE ARE FOUND BY 100'S OF OTHERS. IT'S THE COMPANY THEMSELVES HAVING DIFFICULTIES.
1helpful
2answers
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Top Sirius Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Sirius Car Audio and Video Expert? Answer questions, earn points and help others
