Question about HP PSC 2175 All-In-One InkJet Printer
My printer is: (hp psc 2170 series) When I turn on my printer, the scanner light goes to the right side but instead of stopping and get on stand-by mode, it goes more and more until it gets on the edge and then it starts to make an irritating sound. After 5 minutes the noise stops but the whole printer scanner doesn't work. a lot of people online advised me to clean the mirror (specially when they knew that a bottle of oil was poured on the printer by mistaken) but i don't know what is the mirror or how can i reach it
  • 4 Answers
Follow the instructions here http://www.fixya.com/support/t9851508-printer_hp_psc to get access to the glass and mirror. Use a lint free cloth. After reassembly, it still may not work. Just clean it again. It has to be very very clean.
Posted on Aug 04, 2011
6ya staff
SOURCE:
HP PSC 1400 test page
Cartridge calibration pending in your printer. Put printed align page in to scanner and scan it.. ensure that mono & color cartridge should be in good healthy condition..
Dec 28, 2011 | HP PSC 1401 All-In-One Printer
My hp psc 2170 powers up and then turns itself
make sure the power cord is not loose and there is proper power supply try to connect the power cord in diffrent power unit and check.
Have a nice day and do not forget to rate please...!
Feb 06, 2010 | HP PSC 2175 All-In-One InkJet Printer
HP PSC 1510 series prints alignment test page every time it's turned on.
If you remember, and it´s harder than you think, press and hold cancel when you turn the printer on. Wait till it stops coughing and spluttering and the on button light stops flashing and hey presto. No pescy print page
Apr 14, 2009 | HP PSC 1315 All-In-One InkJet Printer
Need driver for hp psc 2170 series all-in-one
Go to the HP web site and from there you should be able to download the most up to date driver for your Printer. Also try www.download.com
Dec 01, 2008 | HP Office Equipment & Supplies
Need to install printer HP PSC 1500 all-in- One series
i lost the software of psc 1500 all-in-one can you help me?
Jun 13, 2008 | HP PSC 1510 All-In-One InkJet Printer
Having trouble when i turn on my printer
I understand that you are receiving Scanner failure error.
Please follow the below given instructions to get the issue resolved.
Please remove the All-in-One Printer from the Power Surge Protector and plug it directly into a wall Power outlet, as the surge protector may not provide enough power to printer.
Let us power cycle your All-in-one to remove any static electricity in your All-in-one.
Please perform the step given below to power cycle the unit after removing the print cartridges from the printer:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the USB cable from the computer.
2. Wait 30 seconds.
3. Plug in the power only
4. Repeat steps 2-3 two more times.
5. On the third time after plugging the unit into power, reconnect the USB cable from the all-in-one to your computer.
Please try installing the below patch and check for the result:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-14037-3&lc=en&cc=us&dlc=en&product=90809&os=228&lang=en
Just copy and paste the entire link into the Internet browser's address bar and press enter
If the issue persists, try resetting the All-in-one to factory defaults by following the below given instructions:
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold Cancel and the Right Arrow while plugging in the power cord.
Continue holding until it displays S Full Reset message in the front panel of the All-in-One.
This should resolve the issue.
Regards,
Lawrence
Jan 28, 2008 | HP PSC 2175 All-In-One InkJet Printer
HP PSC 1410 will not print, printer icon is no longer on the bottom right hand corner of screen either. When i turn off the printer and turn it back on it prints the test page only.
Dear kappa, It is the problem related "Alignment of cartridge" your printer is working properly, I am suggesting a method, with the help of this method you will never get test page until you lift out your cartridge from your printer. When next time printer print a test page, take it and put it into the scanner, remember the printing area should be the side of mirror and the printer prints on the above side of the paper should be left side of the scanner. And press scan button, you will see the green light will be blink and a voice of scanner you will hear. After 30 seconds light will stop blinking, Next time when you will turn on your printer, it will not print test page.
Sep 24, 2007 | HP PSC 1410 All-In-One InkJet Printer
Hp psc 2175 scanner problem
Firmware problem with unit or a stuck keyboard. This is commomn on the PSC series which includes full scanner head failure. Unplug unit from computer to see if it will do it with no cominication to PC.
Mar 28, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
123 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
