Hold set button into untill function flashes - push and hold set button again to move to next function - continue till all settings are set, https://www.6ya.com/callphilipforhelp
With the power off, push the alarm 1 button, then push the clock set button. Use the skip & preset buttons to set the hour. Push the clock set button again to change to the minute. Again use the skip & preset buttons to set the minute. Push the clock set button again to set. You will see an alarm clock in the upper left of the screen to show the alarm in now set. To cancel push the alarm button and then the stop/alarm off button.
You hold down the sorce button and the display button at the same time. When the clock comes on you push the right button to set the minutes and the left button to set the hour.
1> Press and hold the select button. The setup display appears.
2> Press the select button repeatedly until "CLOCK-ADJ" appears.
3> Press (DSPL). The hour indication flashes.
4> Rotate the volume control dial to set the hour and minute. To move the digital indication, pres (DSPL).
5> Press the select button. The setup is complete and the clock starts.
To display the clock, press (DSPL). Press (DSPL) again to return to previous display.
The clock uses a 12-hour digital indication.
what is the make and model of the radio? if you give me a good rating for this help i will be able to forward the instructions to set the clock, but i would need to know what you have to be able to help
Press "clock" and hold for a few seconds.It will say the day. If the
day is wrong, use the arrow keys to move either forward or backword
through the week. When the day is set press "clock" again and you will
hear the hour. Press the arrow keys to move the hours. Press again for
the minutes and use the arrow keys to set the minutes. Last press
"clock" again and set AM or PM. By the way, the manual does not tell
you how to set the clock.
