Thefirst thing I would suggest is a hard reset. Unplug the unit for aminute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
Your control board may need to be repaired. While these run about $232, we can often repair them for only $39.95 nationwide.
Feel free to contact me directly for more information & help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Tried the hard boot, nothing, left it unpluged overnight an in the morning it worked fine. Electronics must have run down an now things are ok. Hopefully
thanks for the help.....
