I believe they only come in ft......Thanks for the kind words about the site. I am glad to try help others,I find it all comes back to 'ya..
Catch a big one !!!!
Corrosion is caused by small amounts of electrical current flow following the path of least resistance and jumping off one piece of metal to another one thus taking a small piece of metal with it when it goes. You have to either eliminate the current flow or slow it down or make it go somewhere else. The positive ion control in these downriggers can probably add to the problem. Also if you're fishing in salt water, it is a natural electrolyte and if two differnt kinds of metal are in saltwater, they creat a natural battery and produce enough electrical current to corrode the metal. I would suggest maybe using a sacrificial anode. It's a piece of metal with lower resistance to electrical current flow than the metal you're trying to use, thus is corrodes the anode before corroding the metal you're protecting. Anodes are made of metals like aluminum, zinc and magnesium. If you had a small piece of one of those metals and wrapped it around the downrigger spool before you wound the cable onto it, it would rust it out before rusting your cable. You can also try turning down your Ion Control. I've seen my cable rusting a little bit but it doesn't seem to be that bad or rust so fast. I'm wondering if you're using a different kind of metal for your cannonball?
score along the seam with a razor knife just below the cover where the screws are you need to reach an 1/16th inch deep insert a screw driver into the rubber gromet where the power cord goes in and pry open the cover be very carefull not to use any of the insides as a lever and use finess not brute force
