If your freezer is working your fridge is fine
Your problem probably started a couple weeks ago when the drain that allows defrosted ice (water) to drain into the drain pan at the base of your fridge became plugged for some reason. Then everytime the fridge went on defrost more water melted but did not drain which in turn froze. Now ice has built up and caused the air that flows into the fridge to be blocked, causing a warm fridge.... my advice is to leave fridge unplugged for 48 hrs to thaw it and find the cause of the water not to drain... could be a corn niblet or pea from the freezer... the tube should be visible from the inside or the back
The drain tube is not visible.
