Stop 0 Stop 1 gets you in to tech rep mode go to admin settings change your password there.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: services
what kind of problem are you having, please be as descriptive as possible.
thanx,
mikey
SOURCE: i have a Minolta CS Pro EP 1031 Printer that makes streak marks
Drum cleaning blade has gone bad. Especially true if the streaks seem to get progressively worse as you run multiple copies. In other words run 10 copies. If the last one out is worse than the first one out it is the drum cleaning blade. Cheap part...around $25
SOURCE: Minolta CS Pro- Works but print black copy?
Please clean the mirror unit,the trasfer and separator coronas,and perform F5 AIDC control.
SOURCE: please i want clean the copies machine minolta cs pro ep 4000
Dear
the best clean is to take the glass out and clean all the mirrror you can see in the exposure system also you must clean the exposure lamp with the alcohol
that all you can do alse if the the copies still dirty that mean there are another problems in your copier must check.
