Question about HP Office Equipment & Supplies
Hello sir im in ksa ihave an hp designjet 500 series that problem was double print with every line pls tell me solve that problem
  • 283 Answers
Hi and salam Moideen
The problem may be with the calibrations. First of all do the calibrations all i mean Color and line calibrations. If the problem still appears then you have to replace the Paper Axis motor which is responsible in moving the paper forward. If you replace the paper axis motor then you have to perform the calibrations which is a must.
Posted on Jul 20, 2011
6ya staff
SOURCE:
71:06 error code
hello,
Description:
Out of Memory problem. This Error Code only appears in HP DesignJets 800 Series, or in the HP DesignJet 500 Series with an
HP-GL/2 card installed, when processing either a PostScript or HPGL/2 file.
Corrective Action: Try the following:
Check the amount of RAM in the Printer using the Front Panel
(use the Printer Information utility aPage 4-27). If necessary,install more memory into the Formatter.
If the problem continues, try processing the file in the PC instead of the Printer (select Avoid out of memory in Advanced options in the Driver).
hope this helps
Mar 03, 2015 | HP DESIGNJET 500 InkJet Plotter Printer
Hp designjet 500 plus42" print miss some area
1- CHUECK THE HARDWARE OF PRINTER SHAFT
2-THE INK VAT PAPER HAS BEEN TORED
Dec 16, 2012 | HP DESIGNJET 500 InkJet Plotter Printer
Fault code 22:10 hp designjet 500 plus printer
check ur iss (ink supply station) & clean them if problem persists then replaced the iss unit
Jul 30, 2010 | HP DESIGNJET 500 InkJet Plotter Printer
Double printing sometimes-HP DesignJet 500-800 series
When was the last time the heads were aligned? If that's not it, it's the belt.
Dec 17, 2009 | HP Office Equipment & Supplies
HP Designjet 500 System Error 71:06
Check the amount of RAM in the Printer using the Front Panel buttons.
install more memory into the Formatter or
of the Printer (select Avoid out of memory in Advanced options in the driver)
good luck.
Aug 03, 2009 | HP DesignJet 500 InkJet Printer
Hp designjet 500 (42'')
1. remove your catridge
2. remove or change the foam which is located
at the bottom of catridge head
3. hope this will help you to solve your problem
thanks
Jun 16, 2009 | Office Equipment & Supplies
Hp designjet 430
This usually is solved by removing and reinstalling the ink cartridges...make sure the electrical contacts are clean (use a dry paper towel) on both the print cartridge and the carriage.
If the error still happens then the carriage or trailing cable are bad and will need replaced.
Nov 28, 2007 | HP DesignJet 430 InkJet Printer
65 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
