Because your model dehumidifier has an unusual continuous drain hook up, as compared to other brands, I have included a link to the Owner's Manual for your model. You will find the information on page 3. You can downlaod and print the, manual for future reference.
http://www.appliancefactoryparts.com/content/pdfs/123922.pdf
One thing the Owner's Manual fails to mention is the length of the garden hose that can be attached to the unit. It should not exceed 5 feet. As drainage relies entirely on gravity to drain.
I hope this has helped you. Please let e know. Thanks.
Description:
Pump-drain
No. in Pack:
Additional info:
Dehumidifier pump assembly conveniently attaches the pump kit to you dehumidifier. connect a run hose to a nearby sink, pump, or floor drain. this pump will push water through a hose to up to 18 vertical feet for drainage through a window.
Stock Status:
In Stock
Price:
$107.79 -
This part is also known as:
8212501
If you can gravity feed it and can get a hose around the output pipe then any flexible hose will work that is slightly larger than the output pipe.
