Cell Phones Logo
Posted on Jul 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you do call waiting on a KX-TG6523EB phone
Anonymous
Level 3:
  • Master 1,851 Answers
  • Posted on Jul 20, 2011
Anonymous
Master
Level 3:
Answers
1851
Questions
Helped
513429
Points
5186
If you have call waiting activated by your cell phone company [ you many times have to call them ans tell them to activate it].
Once you have the call waiting activated: there are several ways to activate call waiting.
1- You're in a call and hear the 'call waiting beep' - Simply push the TALK button or the button used for TALK on that particular phone.
If you make a call and want to put some one on hold for any reason simply hit TALK after they answer the phone.
Best of it
Gary @ Fix Ya
How do I install my Panasonic KXTGA401 phone?
The KX-TGA401 is a handset for specific Panasonic cordless telephone systems. Connecting the handset requires registering (pairing) it with the base and if the base can support another handset. First make sure that the base is plugged into an active phone line (land line) and that the power adapter is plugged in and working properly. Charge the handset before attempting the registration process.
Then make sure that the phone system is in standby (no calls). Press and hold the Locator button on the base for about 5 seconds (wait until the tone sounds). If all of the handsets that are already registered ring, press and release the Locator button and then press and hold it again. Once you hear the registration tone (some models), place the new handset in the charger on the base. Wait for the long beep and the registered symbol to appear.
If the not registered symbol appears, try registering by using the handset menu. Press Menu # 1 3 0 (the key below 9 and individual number keys) on the handset. Press and hold the locator button until you hear the registration tone as above. Then press Select and Save on the handset within 90 seconds of hearing the registration tone. Wait for the handset and base to complete the registration process. You'll hear a long beep.
The first registration method is given in the manual for the handset, http://help.panasonic.ca/viewing/ALL/KX-TGA401/OI/TGA401_PNQX2390ZA/TGA401_PNQX2390ZA.pdf. The second is from the page 31 of the manual for the KX-TG653x (KX-TG6531 base) system, ftp://ftp.panasonic.com/telephone/om/kx-tg6511_mul_om.pdf . The KX-TGA401 handset works with other bases as well. You may want to check the manual for your phone system in case there are differences. Other compatible phone systems are the KX-TG401x, KX-TG403x, and KX-TG651x.
I hope this helps.
(I make sure that the land line is active by checking for dial tone with an old corded phone.)
How do you cancel "Call waiting" On your Phone?
See manual at http://www.retrevo.com/support/Panasonic-KX-T7453-Telephones-manual/id/2877dj995/t/2/
Bit fiddly, you have to enter a captcha.
looks like the code you are after is on page 30.
PANASONIC MODEL# KX-TGA652 HOW DO YOU ANSWER CALL WAITING?
I am use Panasonic KX-TGA 652 with MagicJack +
How to increase time ring before the answer machine to turn of
My panasonic kx-fl501 fax message says please wait and the keys don't work
I realize this thread is old, but I just encountered the same problem with my Panasonic KX-FL501. Pressing #9000* does not work, as none of the key pads are responding. When I lift the receiver I get a tone. But the keys don't respond when I dial. Display shows "please wait"..... I've been waiting for hours.
Does the panasonic kx-t7431 phone work with caller id waiting feature?
No. CW CID is a function of the system the phone is plugged into. A TD system doesn't have it.
Carl
1helpful
How do I make a conference call on a Panasonic KX-T7436 Digital super hybrid system
while talking to someone:
1) press "CONF"
2) dial the extension number (or 9+the phone number) you want to conference in
3) wait for the person to answer
4) press "CONF" again
1helpful
How do I reach my voicemail on the Panasonic KX-T633? When I press the 'message' button it just calls another extension.
This button is to "
MESSAGE:
Used to leave a message waiting
indication or call back the party
who left the message waiting
indication.
" not retrieve a message.
Here is the manual http://www.reachcom.com/manuals/Panasonic_KXT7625_30_33_36.pdf
There is no voice mail in the phone.
1helpful
Phone keeps saying move closer to base
The handset may have unregistered from the phone. The instructions to reregister it are in the manual, but I'll list them here for you.
1. On the handset, press MENU 001
2. On the base unit
For models KX-TG6021/KX-TG6022/KX-TG6023
Press and hold LOCATOR until the IN USE indicator flashes.
For models KX-TG6051/KX-TG6052/KX-TG6053/KX-TG6054
Press and hold LOCATOR/INTERCOM until the IN USE indicator
flashes.
After the IN USE indicator starts flashing, the rest of the procedure
must be completed within 1minute.
3. Press OK on the handset, then wait until a beep sounds.
4. Press OFF on the handset.
My panasonic kx-t7636 phone has caller id. however
you need to go to the call settings on phone and adjust the call waiting there ok
Music outside the phone
we have kx t 7730 phone and we want to listen to music system outside the phone when not in use what shoul we do please guide
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
