Welcome to Fixya. I would like to know when you turn the laptop on is it running? Can you see the light that indicates that it is on?
We need to check if this is caused by a LCD or motherboard issue. If you can connect an external monitor on your computer and tap FN + F5. This will toggle the display. If you will be able to see the display on the external monitor it means that the problem is the LCD but if not then the problem is the video graphic that is embedded to the motherboard and to be able to fix it is to replace the motherboard itself.
Please let me know if you have questions. Thanks for using Fixya.
Ok,
1. Completely turn off your laptop
2.Take out power bar (on bottom close to back)
3.Hold power button for 30 seconds
4.Put power bar back in
5.It should now work
