SOURCE: fix flash on kodak z740
to try if the flash is working..
*Turn off the camera.
*Install a set of new or fully charged batteries into the camera.
*Turn on the camera.
*Press the Flash Status button to scroll through the flash options until Fill Flash (the lightning bolt icon alone, with no other letter or symbol) is displayed. This forces the camera to use the flash.
If the flash of your camera will not work, refer to www.kodak.com/go/itg for interactive troubleshooting and repair
SOURCE: uploading pics to mac from SD card in camera
Have you tried using an external card reader?
They look similar to this at Wal-Mart:
http://i.ehow.com/images/GlobalPhoto/Articles/4794433/120257_Full.jpg
I own a mac and always use an external usb card reader to download my pics and it works great. Also, I know that you need to get your pics off first, but you may need to reformat you card at some point so that it will read faster and work quicker in your camera.
For your software issue, have you tried download the software from kodak's website? The program shouldn't cause your apple to crash. I would try re-installing it from there website.
http://www.kodak.com/global/en/service/software/easyshare/en/dln_ekn026079.jhtml?pq-path=4509
SOURCE: My KODAK Easyshare z740 Digital Camera turns on 2C
Fixing your problem could be as simple as cleaning the battery contacts
in the camera, or the solution could be a lot more complex and
expensive. Here's a link to the Kodak Help Center - it provides a
simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
SOURCE: I have several pictures on my memory card that I
Create a folder on your desktop and download the pics to that. It usually works. If it doesn't, find a store (like Walmart) that has a Kodak picture maker machine. It will read all the pictures on your card.
SOURCE: Kodak Z740 camera sd card formatting problem
Remove the card...turn on the camera and go into the menu...find "reset"...follow the on-screen instructions. Then try to format the card again.
I'm having the same issue. I'm wondering if it has anything to do with the naming structure of the kodak files. The error message say the file is an unrecognized file format .JPG is what kodak is using.
