You should be able to get this directly from Mackie service. Please see the link below for the contact information. Please note that the exact model number adn serial number will be required to insure that the correct transformer is obtained. There are a few variants of the 1604,
Dan
Link: http://www.mackie.com/support/service/index.html
SOURCE: Mackie 1604 Power Connector orientation
Here's a shot of the connector, mated to the motherboard.
SOURCE: hooking up powerd monitors to a Mackie 1604 VLZ3
Are you sending the main mix to the monitors or are you giving them their own mix? What about using the sub groups, use 1 for your monitor send.
SOURCE: Mackie 1604 VLZ3 Issue.
Hi kielhunt
It sounds like power supply issues.
You may have bad capacitors and/or bad regulators.
If you have a multimeter you can get in there and check the dc voltages for ripple(ac voltage mixed with dc) or over/under voltages along the +/- 15volts lines.
Good luck
Testimonial: "Good ideas, even though he didn't know the answer to the issue fully he was well rounded enough to give great ideas for in-house solutions!"
SOURCE: Can you find me a power supply for the Mackie 1604
Hi, check this link Sweet water.com you will be able to get it there.
Take care.
SOURCE: NEED A TRANSFORMER FOR MY 1604 VLZ PRO..I HAVE
get in contact with this company, i am sure they can help you
http://www.mackie.com/products/1604vlz3/
