SOURCE: Brother 2003D jammed
i am not familiar with the brother safety device myself. however things i would check might be to first check the manual for the machine. if not available try to turn the machine off if it is electronic in hope that it would reset itself. i would also totally unthread the machine and change the needle. embroidery machines need to have needles changed more often due to their high speeds.What type of fabric were you sewing on? Some of the newer machines are just not made to sew on very heavy fabrics and this might be causing something in side to spring. Try to stitch on a lighter fabric with a stabilizer under it
SOURCE: The safety device has been activated.
my SE 270D makes a loud knocking noise and the needle is bending and breaking the safety device came on and the bobbin spring that holds the bobbin in place will move you can pick it up and the bobbin will not stay still when you move the wheel can anyone tell me if that piece would be broke and is it expensive
SOURCE: Babylock ellure safety device
I have the same problem, I have done what the book says but no luck yet. Have you figured out what happened? And do the experts really check the questions? Cause I asked a question awhile ago, and no answers. Help!
SOURCE: Brother 270D Jams when sewing anything
You might have thread caught in the take-up lever linkage and it has soaked up all the oil my recommendation would be take it to your local dealer
SOURCE: the safety device has been activated
Turn off the power supply and open the needle plate.
Remove the bobbin and bobbin case.
Clean the shuttle and surrounding area from any lint or thread that may have accumulated during use.
If the problem continues, the machine will need to be serviced by a Brother dealer.
