Source: Wikipedia
The full hour chime is followed by one strike for the number of the hour by Big Ben (E3) (one strike for one o'clock, two strikes for two o'clock, and so on). ... The mechanism then plays two complete sets of five sequences for each complete hour.
Source: PortableFireplace
Learn how to fix a mantel clock that chimes at the wrong hour. This simple fix will repair a clock that chimes at the wrong time. This can commonly occur when your mantel clock is laid down on its back and the timing is offset.
1 Thing You Have to Understand First
On most clocks you can turn the minute hand counter-clockwise but SOME clocks are not safe to be turned in that direction. For this reason, it's best to only turn your minute hand clockwise just to be safe.
The Simple Mantel Clock Adjustment
The easiest way to adjust a mantel clock chime is to move the hour hand to the hour that the chime is striking. Make sure that the hour hand shaft is not too tight or else it will not turn. Most mantel clock hands are friction held. DO NOT BEND YOUR HOUR HAND, loosen the shaft if it will not turn freely.
Once you have synchronized the hour hand with the hourly chime, adjust the minute hand to set the clock to the correct time by moving it forward (clockwise) around the clock face. Allow the chime to strike at every quarter hour strike.
Mantel clock Chime Adjustment
When your mantel clock chimes the wrong number of times, your chime is not synchronized time of the clock. To adjust your mantel clock chime, proceed with the following step:
ADJUSTING THE HOURLY CHIME
- When your mantel clock chimes, count the number of times it chimes. This is what time your hourly striker is set to.
- Move the hour hand to the hour indicated by the hourly chime (count the number of gongs at the hour).
- Reset the time using the minute hand to the correct hour and the chime should adjust along with the clock hands as well.
ADJUSTING THE QUARTER CHIME
On most mantel clocks, you can simple remove the minute hand which is friction fit. You have to apply pressure on the tube and it will loosen. Once removed, re-install the minute hand at the correct time. From there you can rotate the minute hand to reset the time.
I don't seem to have an adjust button to set the chimes so they will give correct number of rings per hour. I have the dial to change the minutes and a start and stop for the chimes, am pm and the one to change chime 1 and 2. Can anyone tell me what might work. I feel really stupid.
I cannot get the chimes to chime on the appropriate hour. It chimes two times more than what the time is.
The chimes two times more than what the hour actually is.
time is right chiming 10 minutes out
