Saws Logo
Anonymous Posted on Jul 18, 2011
I have a pm2000 3hp left tilt saw that i purchased 3 yrs ago but have never used or even set up until today only to find out the tilting mech. doesn't work
efs_perpends
Level 3:
President:
  • Master 1,997 Answers
  • Posted on Jul 29, 2011
efs_perpends
Master
Level 3:
President:
Answers
1997
Questions
Helped
777314
Points
5779
I bet the grease has set up and the worm gear is just frozen in place. Have you tried spraying some oil or wd40 or silicone lube into the worm gear, and lubricating the trunnion ways? I can't believe that if you've unlocked the handle lock and pushed the handwheel in the saw won't tilt at all. You can download manuals for that saw from here. See page 14 for more details, or get someone who's mechanically inclined to take a look at it for you. If the saw is new, it has a 5 year warranty.See here for repair or parts info.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
  • efs_perpends
    efs_perpends Aug 02, 2011
    I wrote a long comment to this post that apparantly got lost in the ether somewhere. Sometimes posts get unconfirmed and dropped on this site.
    Anyway, if you look at the online users guide you'll see that you have to push in on the tilt wheel to get it into the position that adjusts the tilt mechanism instead of the casters below the saw. The same wheel adjusts both mechanisms. Please read the manual.
My delta shopmaster 10" compound miter saw doesn't tilt
you may have tap the saw to move tilt.
The cuttinghead of your compound miter saw can be
tilted to cut any bevel angle from a 90 degree straight
cut off to a 45 degree left bevel angle. Loosen bevel lock
handle (A) Fig. 19, tilt cutting arm (B) to the desired
angle, and tighten lock handle (A)
Delta MS250 Instruction Manual Adjusting Pointer Locking Cuttinghead In...
Oct 22, 2018 • Delta Saws
I have a jet 10 in. left tilt exact-a-saw that will not tilt. The shaft is keyed to the hand wheel and even wi
First guess would be a lock bolt is tightened down. Second guess would be a 90 degree latch or stop. Take a look at this link from "mikestools": http://www.mikestools.com/download/Jet-Owners-manuals/Jet%20Tablesaws/708661.pdf.
Table saw won't start
You can only tell by using a continuity tester or a multimeter and some troubleshooting techniques.
1helpful
I have a delta 34-444 table saw, is it a right or left tilt, or how do i find out?
Left-tilt, right-tilt refers to the direction the top of the blade can be tilted when it is not straight up and down. There will be an indicator on the front of the saw, normally pointing to zero. When you adjust the blade away from zero, if it tilts to the left, it is a left-tilt saw.
Free manual needed for a alpine cd player for cda-9833
Display Tilt Adjustment
The movable display may be adjusted to 3 different tilt angles
depending upon user preference.
Press TILT 98 to adjust the tilt angle of the movable
http://vault.alpine-usa.com/products/documents/omPush the left side of the front panel until it locks
2helpful
10 inch lest tilt Unisaw will not tilt to complete verticle --only goes to 88.5.
There is an adjustment under the table top. It usually is a bolt with a lock nut that allows you to adjust the table to a predetermined angle every time. You can adjust the amount that the table will go by unlocking the lock nut and then turning the bolt the correct direction allowing the table to come to a full 90 degrees. Once you have the table a 90 degrees lock the bolt down with the lock nut. This will aloow you to change the tilt of the table to something other than 90 degrees and then come back to the 90 degrees by turning the adjusting wheel until it bottoms out against the locked doen adjusting bolt.
I'm missing a ''tilt'' set screw on my Craftsman 10 inch table saw
I couldn't find that model Sears saw to confirm, but if yours is like mine (113.298720), then the handle on the right causes the saw trunion to swivel left and right. And there is a locking hex-head bolt on the front of the saw up close to the underside of the table. This bolt locks the trunion in place keeping it from swivelling.
Take a look at the following diagram http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/P0908018-00004.png part 22 is the shaft that tilts the blade Part 30 is the bolt that locks it in place part 29 is the handle part 28 is the spring that holds the handle on the locking bolt
1helpful
3answers
Bought model 3400 skil table saw. have no manual. can't find control for tilting blade. how do i tilt blade
This model does not have a knob on the side.
There is only a locking lever on the front next to a single rotating wheel for height adjustments. To tilt the blade simply twist the locking lever to the left and push the height adjustment wheel to the right. It can be a bit stiff at times to move.
The blade is not square
Hi, you need a carpenters square. put the square base on the table-saw and the rule against the blade. use your tilt wheel to adjust your blade. turn wheel until there is no gap between blade and table top. if you need more help, please write again
thanks for using fixya
Top Powermatic Saws Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Marty Warge
Are you a Powermatic Saw Expert? Answer questions, earn points and help others
