HOW TO RENAME MY BELKIN ROUTER
Using the WEB BASED INTERFACE.
Using your Internet browser, you can access the Router’s Web-Based
Advanced User Interface. In your browser, type “192.168.2.1” (do
not type in anything else such as “http://” or “www”) then press the
“Enter” key.
You will see the Router’s home page in your browser window.
Clicking on the header of the “Wireless” tab will take you to the
“Wireless” header page. From this page, the Router’s wireless radio
can be enabled or disabled (the default setting is enabled). Under the
“Wireless” tab, there are links that allow you to make changes to the
wireless network settings.
Changing the Wireless Network Name (SSID)
To identify your wireless network, a name called the SSID (Service
Set Identifier) is used. The default SSID of the Router is “belkin54g”.
You can change this to anything you want to or you can leave it
unchanged. If there are other wireless networks operating in your
area, you will want to make sure that your SSID is unique (does not match that of another wireless network in the area). To change the SSID, type in the SSID that you want to use in the “SSID” field (1) and click “Apply Changes”
(2). The change is immediate. If you make a change to the SSID, your wireless-equipped computers may also need to be reconfigured to connect to your new network name. Refer to the documentation of your wireless network adapter for information on making this change.
