Computers & Internet Logo
Posted on Jul 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It gives code 10 error. device can not start - Lexmark International Lexmark X422
Anonymous
Level 2:
Scholar:
  • Expert 88 Answers
  • Posted on Sep 19, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
88
Questions
0
Helped
18313
Points
294
HI
A Code 10 error is generated whenDevice Manager can't start the hardwaredevice, a situation usually caused byoutdated or corrupted driver A device mayalso receive a Code 10error if a driver generates an error that Device Managerdoesn't understand. Inother words, a Code 10 error can sometimes be a verygeneric message indicatingsome kind of unspecified driver or hardware problem.Uninstalling and then reinstalling the drivers for the device is alikelysolution to a Code 10 error. If reinstalling driver is not working than try torollback the driveror restore the system on previous date..
regards
sandy fixya
High definition audio controller This device cannot start. (Code 10)
If you run into the error "This device cannot start. Code 10 (often followed by a driver identifier, for example "This device cannot start. Code 10 in audio driver"), here is what it means.
The Windows error "This device cannot start. Code 10 or "This device cannot start. (Code 10)" is a hardware error that most commonly means that you have a bad, missing, or incompatible device driver. So, for example, "This device cannot start. Code 10 in audio driver" means that you have a bad or missing or incompatible driver for your sound card.
The technical explanation for this message, according to Microsoft, is this:
"If the device has a FailReasonString value in its hardware key, that string appears as the error message. The driver or enumerator puts this registry string value there. If there is no FailReasonString in the hardware key, you receive the following error message:
What does that mean in plain English? It means that if the device which is throwing the error has added its own custom error text to your Windows system when the device was installed, then when the device encounters an error, you will see the custom error message specific to that device. But if it doesn't have its own custom error message, then Windows uses its own generic error message for devices, which is "This device cannot start. (Code 10)"
Microsoft recommends that when this happens, you click "Update Driver" to update the drivers for the device. You can also start the Windows troubleshooting wizard by going to the general properties tab of the device, and clicking on "Troubleshoot".
Before doing this, be sure that you have the correct and most up-to-date versions of the driver(s) for that device. You can also try uninstalling and reinstalling the device, using the disk which came with it.
Finally, you can go to the website of the device's manufacturer, and check their downloads or support section for current, up-to-date drivers.
Go to Toshiba support site look for Toshiba Satellite A135 drivers, download the one for your windows 32 or 64 bit install, restart and off you go. Regards, Mike
Dvd player doesn t work
The Code 10 error is one of several Device Manager error codes. The Code 10 error will almost always display in the following way:
Details on Device Manager error codes like Code 10 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 10 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue.
Cause of the Code 10 Error
A Code 10 error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted drivers.
A device may also receive a Code 10 error if a driver generates an error that Device Manager doesn't understand. In other words, a Code 10 error can sometimes be a very generic message indicating some kind of unspecified driver or hardware problem.
Error Code 10 Troubleshooting
1.Restart your computer if you haven't done so already.
There is always the chance that the error Code 10 you're seeing on a device was caused by some temporary problem in Device Manager or with the hardware. If so, a reboot might fix the Code 10 error.
2.Did you install a device or make a change in Device Manager just before the Code 10 error appeared? If so, it's very possible that the change you made caused the Code 10 error.
Undo the change if you can, restart your PC, and then check again for the Code 10 error.
Depending on the changes you made, some solutions might include:
•Remove or reconfigure the newly installed device.
•Roll back the driver to a version prior to your update.
•Use System Restore to undo recent Device Manager related changes.
3.Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a likely solution to a Code 10 error.
Important: If a USB device is generating the Code 10 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
I am trying to install sound driver on motherboard D101GGC (high definition audio bus) my computer is showing error message Code-10. Please give me suggestions.
HI
A Code 10 error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted driver A device may also receive a Code 10error if a driver generates an error that Device Manager doesn't understand. In other words, a Code 10 error can sometimes be a very generic message indicating some kind of unspecified driver or hardware problem. Uninstalling and then reinstalling the drivers for the device is a likely solution to a Code 10 error. If reinstalling driver is not working than try to rollback the driver or restore the system on previous date..
regards
sandy fixya
Gives error "code 10"
Hi
error code #10 is shown when the device can not be properly addressed and started.
OK, here is what we are going to do. First, uninstall the device from
Device Manager (Start-Run-devmgmt.msc). Now, uninstall the D-Link
Software from Add/Remove Programs in the Control Panel. Now reboot,
then get the latest drivers from D-Link's website. I am linking you to
the drivers for the D-Link DWL-650 (not DWL-G650), but you need to make
sure you have the exact model and firmware version correct. If it is a
different version, go to <a style='text-decoration: underline;' href="http://support.dlink.com" target="_blank">http://support.dlink.com</a> and use the drop down
menus to pick it.
Once that is installed, we are going to disable the Wireless Zero
Configuration Service. Click Start-Run-Type services.msc and click OK.
Scroll down to the bottom, right click on Wireless Zero Configuration
and click Properties. Stop the service and set it to disabled. Click
OK and close that. Now open the D-Link Configuration Utility and
configure it from there.
2answers
Code 10
If you run into the error "This device cannot start. Code 10? (often followed by a driver identifier, for example "This device cannot start. Code 10 in audio driver"), here is what it means.
The Windows error "This device cannot start. Code 10? or "This device cannot start. (Code 10)" is a hardware error that most commonly means that you have a bad, missing, or incompatible device driver. So, for example, "This device cannot start. Code 10 in audio driver" means that you have a bad or missing or incompatible driver for your sound card.
2answers
Code 10 error
okay some ppl have been having the same problem with that device cause the PID number isn't the same
First find out what VID and PID Numbers you have
Step 1 go to device manager locate the "Linksys wireless G usb network adapter" (the name in quotes may be different for you but find your card which should have a similar name)
Step 2 right click on it and go to properties
Step 3 go to details tab
Step 4 either write the VID and PID numbers down or leave that window open to come back to later
Then you find the INF file and open in notepad (the one you downloaded 1xxx for vista)
Lastly in the INF file you locate the section under
; Added support for Belkin and Linksys
And place your VID and PID numbers in the appropriate spot
;Belkin F5D7051
%F5D7051_DeviceDesc% = RNDIS, USBVID_1799&PID_7051
%F5D7051_DeviceDesc% = RNDIS, USBVID_050D&PID_7051
then save the file, re install the driver and restart your PC...
Good luck, let me know
Error code 10 and 39
A Code 10 error usually occurs due to:
Missing device driver
Malfunctioning device driver
Incomplete device driver files
to fix it..........
updating the device driver for the faulty device
1st) To update the driver, select the System option from the Control Panel.
2nd) In the System Properties dialog box, select the Hardware tab,
3rd) select the Device Manager button.
4th) Scroll through the Device Manager window and identify the faulty hardware device.
5th) Right-click on this device and then select the Update Driver command. Next, follow the screen instructions to update the driver of the selected device.
Cd rom wont start (code 10)
Recommended resolution
Device failed to start. Click Update Driver to update the drivers for this device. On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
For more information about Code 10-related errors , click the following article number to view the article in the Microsoft Knowledge Base:
943104 (http://support.microsoft.com/kb/943104/) Description of Code 10-related errors that Device Manager generates on Windows XP-based computers
1helpful
I cant install Computer Speakers can someone help me? Computer says audio device installed but not working properly. Gives error code 10. What does code 10 mean?
Code 10 means that the sound card drivers could not start.... try this:
Goto START.
Right click on My Computer and select properties.
Select the hardware tab.
Select Device Manager.
Here you should see the audio device with a yellow exclamation mark by it.
Right click on it and select uninstall.
Once that has happened look for ACTION in device manager ( Up by FILE and select scan for new hardware.
IF this doesn't fix it you'll probably need to try downloading the latest drivers for the card or it could be defective!
Top Lexmark International Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Lexmark International Computer and Internet Expert? Answer questions, earn points and help others
