Hi first question, does the Technics SL-DZ1200 Turntable CD play SD card with MP3 music format? secondly; I've just recently tried to play a card with some music, it loads up but I'm not getting any response form the start/cue control , can you advise.
SOURCE: How do I change belt on a Technics linear SL -H350 turntable
http://www.archive.org/details/Turntable_Belt_Installation
above video should help. if your platter is "stuck" then call them for tips. also make sure it does NOT say "direct drive" on the front of the unit.
presuming you are talking about the SL-H350 as in the body not the SL-DZ1200 as in the title
SOURCE: records alone and auto cue
this should help....follow instructions i just done mine with a 64mb nokia micro sd card from ebay (£3)
http://www.technicsforums.com/forums/index.php?topic=5.0
SOURCE: looking for manual for a turntable sl-1700
Hi
You can down load the user manual and the service manual from here
You have to register to download them, but they are for free!! Good luck, happy to answer any questions you may have.
regards
robotek
SOURCE: My Technics SL-DZ1200 will not play certain MP3
I believe it can only read certain bitrates. I noticed that if I run the track error files through audacity and re-save as an mp3 with 192 kbps encoding it plays fine. Give it a try - re-encoding.
SOURCE: Technics SL-1700 Mk2, tonearm doesn't lower, cueing doesn't work
There's a rubber belt or O ring that broke. I couldn't find one at Technics, so I took the old parts to the hardware store and found an O ring in plumbing parts that was very close. Been working for years just fine!
Eddie
