Question about Smart Pulse Livescribe pen
The LCD screen does not show all of the pixels anymore, only some. It's getting worse.
  • candiville Jul 19, 2011
    Hi Ezrahite, i am using a Dell Dimension 4600 Desktop. Dual core, 3Gig processor with 4 Gigs of Ram. My livescribe screen has workesd fine for the past 11 months until now.
    Francis V
  • warner45w
    warner45w Dec 04, 2019
    The official website of NJMCDirect is www.NJMCDirect.com it is an online portal where you can pay fines. This website will provide you a prefix code to pay the ticket fines.
    njmcdirect |
    www.njmcdirect.com |
    njmcdirect.com
    Guru:
  • 610 Answers
We need to check if the issue that you have is a dead pixel or a stuck pixel. If it's a dead pixel (a black dot that doesn't respond to color changes), unfortunately, there is no way to fix it. If it is a "stuck pixel" normally a dot with a color but doesn't change correspondingly, this can be fixed via a software or some alternative methods.
You can download Pixel Doctor here: PixelDoctor download link
Its a .rar file so you need to extract it before you can use it. Pixel Doctor is a handy utility that will enable you to easily repair the stuck pixels on your LCD screen.
To fix a stuck pixel, select a color and the Start Single Test. If you see any dead pixel/s on your LCD screen, run the Start Therapy tests, I suggest you use Full Screen Method since you mentioned that you have a lot of it on your screen. Run it for about 10-15 minutes
Or you can also try these alternative ways of fixing stuck pixels on your LCD: Click Here
Hope this works for you.
Posted on Jul 19, 2011
  • 2,632 Answers
Welcome to Fixya. I would like to know if your using a desktop or a laptop? Can you also please provide the make and the model of the computer so that we can check what seems to be the problem. Please provide the information needed to be able to provide a solution to fix it.
Thanks
Posted on Jul 18, 2011
  • Rofel Lantican
    Rofel Lantican Jul 19, 2011
    Hi - If the lcd wont show all the pixel the problem here is that the LCD of the livescribe you can the warranty and check the manufacturer if they can replace the lcd or replace the whole device. Thanks
  • J vanWalsum Jun 08, 2013
    They do not replace, nor provide a fix. I believe they "broke" the pen with a bad firmware update. I have 3 pens with LCD screens that stopped working completely all around the same time. Class action lawyer please.
6ya staff
SOURCE:
Vertical lines of stuck pixels
If a LCD TV has vertical or horizontal lines, in most of the case the problem is a defective LCD panel.
Jul 01, 2017 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
The left half of my LG LCD TV is going bad. Can anyone suggest a fix before we have to pay a repair tech?
I just fixed this problem on my friend's a couple of days ago. It is indeed the tcon board. It does not need to be replaced though! I just took it apart, cleaned the grounding connections with isoprol alcohol, and double checked all connectors. Turned it on and it worked great! I hope this helps yours and anybody else's problem! A lot cheaper than sending it in for repair. Don't try this if you're inexperienced at fixing electronics though. There are some high voltages built up in the power supply.
Apr 23, 2012 | LG 42LC2D 42 in. LCD HDTV
A spot developed in center of screen next day black lines across screen from the original spot
it sounds like you have a small crack on your screen that has gotten worse over time, these black areas are where the lcd crystals aren't active anymore, unfortunately there isn't allot you can do apart from buy a new screen or put up with the black lines.
May 02, 2011 | Gateway FPD 1730 17" Flat Panel LCD...
Dark vertical streaks on the screen (they look like a liquid flowed down the screen). They are worse on a darker screen. In fact they do not show at all on a white screen. Sometimes the screen also shows...
HI:
There could be one or two problems with this symptom. One is the Panel could be failing and the other is you may have a bad T_CON board. This board does the work of putting the picture on the screen and lighting up the different color pixels in the screen and also does the adressing of these pixels. I would replace the T-Con board first for the line problems, AS to the liquid this may be due to a faluty Panel screen where the fluid is escaping from in between the LCD screens, in which case I would contact Dynex to see if they will replace the Screen for you. The only option is to replace the screen at this point.
Apr 20, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Vertical lines on lcd display, just a few at first but getting worse
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical lines. Usually screen replacement is the only answer to fix it. You can usually find replacement LCD on Ebay.
Dec 29, 2010 | Toshiba Satellite P105-S6104 Notebook
Hp ze4900, has a thin line down far right side of screen, is this video, driver or screen problem?
pixel problem,,,,,, so i suppose it is the screen that is bad in that 1 line. if you can ignore it and do not bang that laptop anymore it shouldnt get any worse
Nov 08, 2009 | Compaq Presario M2000 Notebook
3 pixel wide stripe on lcd
Hi Casey,
If the problem is getting worse, than either the pixels are dying (so to speak) or you might have a problem with the monitor's screen.
Unfortunately, if either of the above are true, then the only way to fix it would be to replace the screen, which can be quite expensive. If you agree that this is the problem then you'd be better off getting a new monitor instead of spending money to get it repaired.
Good Luck.
Jun 07, 2009 | Acer AL1711 17" LCD Monitor
Dell Inspiron E1505 shows green pixels instead of black
the color pixels are different sections in the screen and the green section might be cracked
Apr 24, 2009 | Dell Inspiron E1505 Notebook
The is a very small blue dot on my Canon xti screen
It can be regarded as normal, yes. All LCD screens will have a percentage of dead pixels, and no manufacturer will guarantee you get a dead-pixel screen on their products.
As you say it does not affect your photos and you can be assured it is not something that is going to get worse - it is a tiny manufacturing defect that is all, but within what they call acceptable limits.
If the camera is brand new you could always take it back and ask for another one, but they are within their rights (I believe) to say no for a single dead pixel.
Jan 25, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Lcd problem white pin dot on screen
Probaly will not get worse, but is a stuck pixel. If you press on the screen at that pixel, does it go away? Check with mfr see if it is covered.
Jun 05, 2008 | Dell E173FP 17" LCD Monitor
Smart Pulse Livescribe pen Logo
1,159 people viewed this question
Top Smart Computers & Internet Experts
Marvin
Marvin
pawnpower
Are you a Smart Computer and Internet Expert? Answer questions, earn points and help others
