Delonghi DE500P quit pumping water. For the last two week it sounded like a bearing was going out. Would just cleaning it out solve the problem as described in the cleaning problem solutions
Pump is defective.Is your pump light going on and off???If it is it means the pump is defective.I fiddled around with mine for a day and finally realized the pump is the culprit.So i stopped using the pump,which you can switch off on the panel...where it says pump.Finally I just drilled a hole into the continuously draining hole at the tank and put a tube into it and the problem got solved [email protected]
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
First, make sure the humidistat isn't set too high by adjusting it to
the lowest humidity setting and running it again. Next, test the
dehumidifier by placing it in a closed bathroom with a hot shower
running. If you don't see water collecting in the unit after several
minutes, turn the unit off and clean all dehumidifier filters and
coils. If, after adjusting the settings and cleaning the unit, you
still don't see water collecting, you may have a refrigeration issue.
This situation will have to be addressed by a qualified technician.
the motor is tight, (can't turn) lubricate the motor bearings with light machine oil. retest. rust causes this. the motor "tries" to turn, more power is needed, still can't turn, power exceeds safe limits: breaker trips.
This appliance has 3-ft drainage hose and a 16-ft pump hose. I searched for a store that carry these hose, unfortunately, none of them sell a part or accessory for the DE500P.
Kindly click this link and verify if they could sell a hose:
I only got as far as disconnecting the filter between the small water bucket and the pump. I was able to get the pump working again after I cleaned the water bucket and filter by flushing them repeatedly with fresh water. The lines after the pump contained cloudy water, but I figured since the pump was able to push it out past the pump already, it shouldn't cause problems this far down. It saved a lot of time and hard work not having to disconnet the rest of the tubing or take the water bucket off. I also realized if I disconnet the first water collection tubing from just under the front panel and point the open end down, all the water in the bucket flows out. This part is so easy to get to. Just pull out the big collection tank and it's right there on the left toward the back. I can do this every week! Maybe then nothing will sit long enough in the small water bucket to turn into any kind of filter-clogging material.
