SOURCE: Will not record on a DVD R
what I would do is play the vhs tape for a bit then rewind and press the dub botton only and see what happens. if nada then insert a new blank dvd and make sure its formated.
SOURCE: Can't play finalized DVDs dubbed from VHS on other Sony DVD players or PC
It sounds like the disc were not finalized properly. Are you sure the player finalized the discs?
SOURCE: VHS TO DVD DUB ERROR ON PLAYBACK
Chariot
Had the same problem. I have the Sony RDR VX560 which I presume is similiar. You left out one step after dubbing. You need to "Finalize" in order to play the DVD in other equipment. See System menue or read the Operating Instructions. It would probably been appropriate for Sony to put a footnote in the dubbing instructions. Oh well.
DLA
SOURCE: VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
SOURCE: vhs to dvd - "simple dubbing" greyed out, help please thank you!
check your software, what are you using???? Free software is available at Burnworld.com
