0.03 ohms? Should read 'short' if it (the fuses) are good. Does your Volt Ohm Meter have a position that beeps if it reads a short? (touch one probe to the other to produce a short and observe the reading) You should get the same reading on a good fuse ... beep or reading. Is your microwave 220 volts?
There is not much that goes wrong with a microwave,really. You are on the right track. Test the fuses. If you get power but no heat, I recommend you suspect (and inspect) the door safety interlock micro switches. If these switches fail, the oven doesnt know if the door is open or closed.
Let me know what you find out please ...
Thanks for your interest in FixYa.com
Whirlpool is conducting a safety recall on the Kitchenaid KHMS155L series (and similar models under other brand names) that display the F2 code or have been observed self-starting. Other symptoms may be additional codes or unintelligible info being displayed, and failure to execute the command entered into the control pad. To obtain free replacement of the control panel, call Ava at Whirlpool: 1-866-640-7146, extension 6337. She will want your complete model and serial numbers and a phone number and address where you can be reached. She will arrange for A & E Factory Service to contact you to set up an appointment to come out and replace the control panel at no cost to you.
