Solution for : My Pandigital (white) wouldn't turn on and had no light. This is what worked for me:
Remove the back cover...just below the pandigital logo on the back (slightly below the crack) press your thumb in the middle and slide the back down. I had to do it a few times, but it did come off. Then unplug the battery (the two wires with the white plug). Then plug in the charger (on the side) and replug the battery in. That might solve the problem but if it doesn't .. then press power, volume and reset (using paper clip) at the same time for thirty seconds. Then release and that might solve the problem, but if a triangle shows up: simple repress the reset button once. Then, unplug the charger, replace the back cover, and replug in the charger. Thanks to whom ever posted these solutions in the first place. It worked.
