2007 KIA RIO Remote keyless entry Logo
Posted on Nov 01, 2017
The remote doesn't work - and then when you unlock the door with the key - the alarm will go off. This happened about 5 times and then the remote worked - the alarm did not go off and the car started with no problems. Two different remotes from the car were used so the battery wasn't dead in the remote. What do we need to do?
Morgan Kane
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 16 Answers
  • Posted on Nov 01, 2017
Morgan Kane
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
16
Questions
Helped
6142
Points
44
Try to have your remote re-programmed. You must go the the car brand you have. All electronic can have malfunctions.
Also check if you have good enough batteries in your remotes. If new batteries does not help, re-program the controller.
5 Related Answers
Anonymous
  • 578 Answers
  • Posted on Aug 20, 2009
SOURCE: Remote stops working and then in a few weeks starts up again.
if its a factory remote you have to check your deal if the vehicle is doing all those function you may have a bad module on one of those function
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Dec 03, 2009
SOURCE: 2006 kia spectra. The power door locks
security ----encrypted software dealer only
Anonymous
  • Posted on Sep 28, 2012
SOURCE: I HAVE A 2004 KIA AMANTI AND IT WON'T LET ME IN AND THE BATTERY IS DEAD HOW CAN I GET INTO THE CAR FROM THE OUTSIDE WITHOUT THE REMOTE OR KEY? I ALSO CAN NOT GET UNDER THE HOOD.
This sounds all to familiar. I was an owner of one of these 2004 amantis as well. If youre 100,000+; sell it before the real problems start. Its a design flaw; I just about flipped when mine did this so I have been there. Only way is to slim jim the door and then pop the hood& pray for power after jumping. The key in the door wont work bc its electric; same goes for key faub, all keyed entry doors,& the trunk! I dont know what these guys were thinkin or smoking when they designed this model. Good luck!
sulavaca
Jamie Alton
  • 1007 Answers
  • Posted on Nov 14, 2012
SOURCE: Opening car with key sets off alarm.
Open up your key and dry it first of all.
Then retry.
Or you could try using your spare set of keys.
Randy Ohler
  • 14585 Answers
  • Posted on Jan 24, 2015
SOURCE: Kia sorento wont crank after remote start worked and battary is not dead. Opened hatch and cut off as suppose to but won't crank now with key or remote. Please help
Have the remote start removed from the vehicle. Fix the cut wires. Use the key.
tip
How to Program Acura Remote Transmitter
Acura Remote Alarm / Central locking
Model: CL Year: 2001-2003
Model: TL Year: 1998-2006
Model: MDX Year: 2001-2006
Model: RDX Year: 2007-2009
Model: RL Year: 1996-2004
Model: RSX Year: 2002-2007
Model: TSX Year:2004-2008
System Operation
  • Pressing remote transmitter LOCK button once activates alarm and central locking.
  • Pressing remote transmitter UNLOCK button once deactivates alarm (if fitted) and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button once also activates driving position memory. Driver's seat and mirrors move into memory position specified on remote transmitter when driver's door opened.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds unlocks all doors.
  • Pressing remote transmitter trunk release button for 2 seconds activates trunk release.
  • Pressing remote transmitter PANIC button for more than 1 second activates panic alarm.
  • Pressing any of the remote transmitter buttons deactivates panic alarm.
  • If vehicle unlocked and doors not opened within 30 seconds, locks are reactivated.
Synchronization.
when
  • Remote transmitter battery replaced.
How
  • Press remote transmitter LOCK button or UNLOCK button 5-6 times.
  • System should now lock and unlock vehicle to indicate synchronization procedure complete.
  • Check operation of remote transmitter
Programming
How
  • Obtain all remote transmitters.
  • Switch ignition ON.
Proceed as follows:
NOTE:Point remote transmitter at central locking signal control module (located behind glove box).
  • Within 4 seconds: Press LOCK button or UNLOCK button of first remote transmitter.
  • Within 4 seconds: Switch ignition OFF.
  • Within 4 seconds: Switch ignition ON.
Repeat procedure above twice.
  • System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds:
  • Press LOCK button or UNLOCK button of first remote transmitter, allowing doors to lock and unlock once.
  • Press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Switch ignition OFF.
  • Remove key
  • Check operation of all programmed remote transmitters.
Immobilizer
System Operation
  • System arms 5 seconds after switching ignition OFF. Immobilizer warning lamp flashes during this time
  • Immobilizer warning lamp illuminates for 2-3 seconds.
  • If immobilizer warning lamp illuminates for 2-3 seconds then flashes rapidly:
  • Key code not recognized.
  • Remove key and try again.
Programming
When
  • System malfunction.
  • Key added or replaced.
How
Immobilizer can only be programmed using diagnostic equipment.
Model: MDX Year: 2007-2009
Model: TL Year: 2007-2008
System Operation
  • Pressing key LOCK button once locks the vehicle.
  • Pressing key LOCK button twice within 5 seconds activates the alarm.
  • Pressing key UNLOCK button once unlocks the driver's door only and deactivates alarm.
  • Pressing key UNLOCK button within 5 seconds unlocks all doors and tailgate.
  • Pressing key UNLOCK button within 5 seconds and holding will open windows and sunroof
NOTE: Models with "Technology Package": Alarm central locking functions can be altered using digital multifunction display in instrument panel.
  • Pressing key PANIC button for more than 2 second activates panic alarm.
  • Pressing any of the key buttons or turning ignition ON deactivates panic alarm.
  • System will automatically lock all doors when vehicle is driven above 15 mph (if function selected).
  • If vehicle is unlocked and doors or tailgate not opened within 30, 60, or 90 seconds (depending on programming), locks and alarm system are automatically reactivated.
  • Pressing tailgate release button once will open, close or reverse direction of tailgate.
Programming
When
  • Key remote transmitter added or replaced.
How
  • Obtain all keys fitted with remote transmitters.
  • Ensure doors, trunk / tailgate and hood are closed and unlocked.
NOTE: A maximum of 5 remote transmitters can be programmed.
Proceed as follows:
Repeat procedure above twice. Locks should cycle when button in pushed.
  • Within 4 seconds of each other press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Remove key.
  • Wait 10 seconds.
Immobilizer
System Operation
  • System arms when vehicle is locked using the remote transmitter.
  • If key code is not recognized:
  • Engine starts, then shuts off.
  • Immobilizer warning lamp flashes once, then blinks until ignition is switched OFF.
  • With ignition switched OFF, immobilizer warning lamp will flash 10 times to indicate the system has reset.
Programming
When
How
Model: RL Year: 2005-2009
Programming
When
  • Remote Transmitter added or Replaced.
  • System Malfunction.
How
Remote Transmitters can only be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Acura Remote Transmitter Programming...
on Mar 26, 2015 • Televison & Video
Alarm went off, now the central locking doesn't work
use the car key itself from outside the vehicle with everything closed: use key in drivers door outside door lock and manually lock and unlock the door. check if fixed, may have to do a few times. i do believe the vehicle is in theft mode.
4helpful
How to reprogram Python 4Button Remote 474P ?
I had the exact same thing happen with my 4-button 474p remote. WITHOUT REMOTE START the correct sequence is:
1. Enter car - Leave door open.
2. Turn key to "on" position.
3. Within 5 (five) seconds press the Valet button 7 times then hold down. (Programs to channel 7)
4. Watch alarm light - It should now flash 7 times.
5. While still holding down the Valet button - Press the "lock" button on the remote and release. Should get a "chirp"
6. Now release and repress the Valet button once, holding down. You'll get the "chirp". Release Valet button.
7. Turn key "off". Exit vehicle and test remote. All 4 buttons should now work.
My 2000 hyundai tiburon alarmed itself and the alarm is sounding. I have no remote control that works.
Put key in ignition, turn all the way forward, but not trying to start. Let alarm cycle 2 times, when it stops the 2nd time, remove key and alarm should be disarmed. This will only work if it is a factory alarm.
2helpful
2answers
I think I messed up the remote programing.. When I press to lock the doors they do lock but the horn doesn't honk anymore.. The blue light on the dash does not light up either.. I can still remote...
If the led is solid blue when the key is out of the ignition that means your in valet mode. Which would disable the alarm, but not the starter.
Simply turn key to IGN position then back to OFF.Push the valet button which is on the antenna next to the led and the led should turn off.Close door on vehicle and lock vehicle.Siren should now chirp.
Cheers!!
2answers
HELP please!! My daughter has a 96 sebring convertible and today she put her key in the door to unlock it and the alarm started going off. It wont stop, have disconnected the positive and negative battery...
Just a quick note once you hook the battery back up try locking it and unlocking it from the drivers door, if that fails you might try the passenger door. I know on some chrysler products you have to lock and lock again to arm and unlock to disarm. I hope this helps.
Thanks,
Joey
6helpful
WHEN I PUSH TO BUTTON TO UNLOCK MY 2007 HYUNDAI VERACRUZ LIMITED, IT UNLOCKS OK BUT THEN WHEN I OPEN THE DOOR THE ALARM SOUNDS UNTIL I TURN THE IGNITION SWITCH. AFTER THAT, EVERYTHING OPERATES NORMALLY. ...
the car has two codes one is fixed the other is a rolling code which changes each time you press the unlock button,the first is allowing you to unlock the car but when you open the door it thinks your trying to steal it and the alarm goes off,then when you put in key it is recognising the key and switching off the alarm....NOW if you follow the instructions in the book you can reset the alarm(as i worked for hyundai over 5 years ago i cant remember the sequence,sorry)
10helpful
3answers
Program remote control for mazda mpv 2002
Courtesy of: forums.mazdaworld.org
Try this, it works on several 2002 models:
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the drivers door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the drivers door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done
Top Kia Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Kardoc
 Mikey
Mikey
Are you a Kia Vehicle Part and Accessory Expert? Answer questions, earn points and help others
