Whirlpool Accubake Stove
When oven is turned on, it pre-heats fine but then stops baking. The light come on and off saying it's heating, but bottom element won't come on again. We've tried everything. Is this an electronic problem? There are no fuses to be found.
Is this an over the stove type unit? I have had a few problems with my over the range spacesaver. I think the heat from cooking gets up into the microwave and damages it. The steam from me boiling things on the stove had mine quit heating and I purchased a new one. The parts to replace the faulty ones can be quite expensive over $150.00, so its better to purchase a new microwave.
i have seen elements short out and cause the main board to fail. if eeverything else works you know you have proper power , so i would say the board is bad
If the gets give no gas then sounds like a Thermocouple, this is a device that allows the gas to come on after a period of time ensuring that the pilot is lit and heated up this thermocouple, once it heats it then allows gas to enter and ignite the main burner..hope this helps ,please leave feedback.
This is becoming a common problem. If your dual burners are controlled by the burner switch only, then you need to replace your dual burner infinite switch. Some models have a seperate rocker switch that switches from small burner to both burners. If you have this style then this is usually your problem. Can also be from shorted wiring but this is very unlikely. Good Luck, Appliance Specialists
