I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1
Stand on the side rails of the treadmill for safety purposes. Remove the safety key.
Step 2 Press and hold the two
incline buttons. The incline buttons are blue and on the left side of
the display. Hold the up and down button simultaneously. Release the
buttons when the display reads "Calibration."
Step 3 Press the green start
button located either above or below the large, red stop button
(depending on your model). Stay on the side rails as the treadmill belt
begins to move. Both the speed and incline should go through their full
range from lowest to highest, and then back down again.
Step 4 Repeat the process if the
display does not read "Calibration Successful." Contact the business
where you purchased your treadmill if repeating the calibration process
does not result in a successful calibration.
I have now got my treadmill working, Thanks
Hi
I have the same error code. I tried the solution but can't get the calibration to start, I have tried pressing the incline buttons at the same time on their own, presseing both and then the power button, pressing the power button then both togeher straight away....but to no avail. Have you any suggestions for me please?
Thank you.
Can I clear internal memory from giiNii 8dn dpf directly to a USB flash dive so I do t lose my pictures?
jura ena micro 1
