Sharp R-510HW Microwave Oven Logo
Posted on Jul 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sharp Microwave 1200 Watt Carousel stopped heating and carousel stopped turning. LCD lights work and timer and clock works. Can you fix it by replacing a fuse in th Microwave? If so where is the fuse located?
  • Anonymous Mar 18, 2014
    REplacing fuse in sharp R-772M microwave
Anonymous
Level 3:
  • Sharp Master 43,501 Answers
  • Posted on Aug 13, 2011
Anonymous
Sharp Master
Level 3:
Answers
43501
Questions
0
Helped
10845426
Points
101584
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 -==-
Sharp carousel 1200 watts microwave manual
They is one of the DOOR SWITCH need to replace
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
My sharp 1214 won't heat anything. power is good - timer and clock are fine. stopped working in the middle of heating something. we use often. carousel is not rotating anymore either.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
It's not getting heat and LCD looks like there's water inside.
On most Sharp Carousel Microwaves, the display stops working after time. As for the not getting any heat, the magnetron or the high voltage transformer may not be working.
10helpful
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Sharp carousel r-508ak - does not heat up the food
You probably have a defective magnetron or blown fuse supply power to magnetron.
3helpful
2answers
Sharp Carousel Microwave Model R520-LK timer will run but carousel doesn't turn and food doesn't heat.
I also have the Sharp Carosoul oven, symptoms - fan runs, controls are fine but the turntable stopped turning and it did not heat. It was not the switches, fuse, but in fact a sagging door that misaligned with the door switches. The true cause was a warn top hinge. As a temporary fix, I adjusted the bottom hinge (3 screws underneath), straightened the door, and now it works again.
1helpful
Sharp Carousel Convection Microwave R-9H56 suddenly stops heating
at highvoltage section wiring may bae problem, check wiring and connectrors of magnetron and capacitor and transformer.
No heating, no clock, no timer, otherwise fine!
One of your door interlock switches is defective . I would suggest having it repaired by a qualified repair tech in your area.
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
