Do you have the full software (MP Navigator) installed? Get that software here:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp510#DriversAndSoftware and select your OS. Since the printer is a USB printer, is it directly connected and did you install the software before connecting the USB cable? If you didn't install the software before you connected the USB cable, uninstall the generic driver from the OS and remove the USB cable. Then install the software.
If the full software was installed before connecting the printer, try a new cable and a direct connection (instead of a print server or USB hub). Scanners require bi-directional communication with the computer and can fail when the printer works. Make sure the monitoring program is running before attempting to scan from the all-in-one.
Next try to scan from the computer first. There are buttons in the MP Navigator software that set the destination and default settings of the buttons on the all-in-one. After you scan at least one item, you will have a better idea of the settings that you need to use. See the MP Navigator help files for the details.
If you install the basic Canon driver, you will be able to scan but not from the unit directly. Windows XP and newer all come with Paint that can acquire scans (File > Import from Camera or Scanner > New Scan). Windows Vista and Windows 7 have Windows Fax and Scan that can also scan files (New Scan). Photo Gallery in Windows Live (comes with Vista) also handles scanning.
The generic OS driver usually only runs the printer.
I hope this helps.
