if I unplug and of the ribbon cables on my separates the whole system switches of, anyway around this problem. looking to get rid of both the graphic equaliser and the tape deck leaving only cd player and amp.if I unplug and of the ribbon cables on my separates the whole system switches of, anyway around this problem. looking to get rid of both the graphic equaliser and the tape deck leaving only cd player and amp.
You can't post conmments that contain an email address.
It could be stuck or jammed then or the parts that allow the door to open could be broken. There are video's on YouTube about how to a CD player or a DVD player that will not open up.
1 Open top door (display shows OPEN)
2 Press and hold SERVICE button until beep (display shows P5)
3 Press and hold CLEAR button until beep (approx 25 seconds)
4 Press and hold SERVICE button until beep
5 Close top door
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams. Make sure your tray retracts all the way into the player flush with the face plate, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position. Applicable to:
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses. Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts. Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position. Applicable to: Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751 also: Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
You could try to spray some oil into the spindlemotor, sometimes(very rare) they tend to stick a bit and will not turn properly or keep the right speed.
