Question about Palm Tungsten T5 - Multilingual Handheld
Help setting alarms
How do I use Alarms?
  • Anonymous May 11, 2010
    how to set up time and date on palmtreo 500?
How to set up time and date?
Posted on Dec 18, 2008
    Master:
  • 903 Answers
To set an alarm for an event: 1. Create a new event or double-click an existing event. 2. In the New/Edit Event dialog box, select the Alarm check box. 3. Click the time interval selector and select Minutes, Hours, or Days. 4. Type a number between 0 and 99 in the Time Measurement box. 5. Click OK. To set a default alarm for all new events: 1. From the Tools menu, choose Options. 2. In the Options dialog box, click the Date Book tab. 3. Select the Alarm Preset check box. 4. Click the time interval selector and select Minutes, Hours, or Days. 5. Type a number between 0 and 99 in the Time Measurement box. 6. Click OK. Setting Alarm Options You can configure the Alarm Manager settings for the Desktop application in the Alarm tab of the Options dialog box. To set Alarm options: 1. From the Tools menu, choose Options. 2. In the Options dialog box, click the Alarms tab and click one of the following actions: * Always available: Click this option if you want alarm notifications to appear regardless of whether the Desktop application is running. * Available only when Palm Desktop is running: Click this option if you want alarm notifications to appear only when the Desktop application is running. * Disabled: Click this option if you do not want alarm notifications to appear on your computer. 3. If you want an alarm tone to sound when the alarm notification message appears, click Play audible notification with alarm dialog. 4. Click OK.
Posted on Sep 07, 2005
The alarm is set and I do not want it go off anymore and I cannot find a way to clear it
About 5,060,000 results (0.64 seconds) Search Results
    Set or cancel alarms and snooze - Android One Help
    support.google.com > Android One Help > Apps > Clock
    GoogleSet, delete, and label alarms Set new alarm or repeating alarm Open the. ... Open theClock app Clock . Touch menu More > Settings. Under "Alarms," you can ...
    How to Cancel the Android Alarm ' Chron.com
    smallbusiness.chron.com > ... > Start Up Businesses
    You can cancel your alarm after it goes off to stop that occurrence ... ... going off; turning an alarm off has to be done by managing the app's settings. ... Alternatively, you can tap "Snooze" to set the alarm to go off again after the ... Tap "Clock.".
    Setting and using the alarm - Bose
    worldwide.bose.com/...setting...alarm/page.html
    Bose CorporationLearn how to properly set and use Alarm 1 and Alarm 2 by following these ... There are two alarms indicated on the clock display as ALARM (primary) and ...
    How do I set, cancel, and delete an alarm (including settings ...
    support.lenovo.com/us/en/documents/ht101173
    Lenovo
Jan 30, 2016 | Home
How do I unhide alarms 2 and 3?
Set multiple alarms. If any alarm is active,(picture of alarm hear) appears in time display A. Press MODE repeatedly until ALARM appears, followed by ALM1. Press STOP/RESET to select Alarm to set. B. Press SET/RECALL to set alarm. HOURS digits will flash. Press +/- to change HOURS. C. Press NEXT and +/- to set MINUTES, AM or PM (if primary time display is in 12-hour format), DAILY, WKDAYS, WKENDS, or day of the week (weekly alarm). D. Press DONE to exit. E. Press +/- to set different Alarm. Set as above. F. In Alarm mode, press START/SPLIT to turn Alarm ON or OFF. TIP: Alarms apply to selected Time Zone of watch display. Backup Alarm sounds after 5 minutes if no button is pressed. Turning off any Alarm or backup will not affect other alarms. http://assets.timex.com/user_guides/W191_M131/W191_M131_NA_EN.pdf
Dec 01, 2015 | Timex Sports Ironman Triathlon 100-Lap...
How do I keep the alarm from flashing? I just want to turn off both alarms. Timex nature sounds with cd T621T, Thank you
Hello, To turn off the alarms follow these steps -
  1. After the alarm sounds, press the "F" alarm off/reset button to shut the alarm off but retain the 7-5-2 alarm settings.
  2. If you want to turn the alarms completely off and cancel the 7-5-2 settings, press the "alarm" button so that the "alarm" indicator is no longer visible. As long as you can see the word "alarm" on the display the alarms will continue to go off according to your 7-5-2 alarm settings.
Regards, Tony
Mar 24, 2011 | Timex Nature Sounds LED Clock Radio
Alarm setting
What settings in alarm do you need to set? In case you want to set the alarm time, tap Start >> Settings. Go to System tab and open Click and Alarms, tap on Alarms tap at the bottom and you may set the alarms from there.
In order to set the alarm tone, tap Start >> Settings. Open Sounds and Notifications in Personal tab, make sure that the checkbox for Programs and Notifications is checked. Now go to Notifications tab, in the event select Reminders and you may configure the alarm behavior and ring tone in there.
Please rate the solution.
Dec 14, 2009 | HTC Touch P3450 Smartphone
Alarm goes off at midnight & repeats for half hour, and not set
what you have to do is
1. press the mode button until you get to the setting that has "AL" at the bottom right.
2. then you press the "receive" button to switch between the four alarms.
3. as you are going through each alarm time, you need to look in the circle at the top right. When you are going through the alarm times, if there is a mark next to "ALM", you need to press the "time memo" button so that the mark next to "ALM" is no longer there.
4. repeat step fout for all of the alarms, and the problem should be fixed.
Apr 13, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Alarms, alarms, alarms
Press mode until in Alarm Mode
Press Receive until alarm # shows AL1-4 or Sig
Press Time/Memo to change alarm on or off. On is shown by indicator next to alarm name.
Mar 04, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Setting Alarms
Here is a link that might help. Just make sure you have the latset version of Adobe Reader. Click on the model/version number and start to dowload. It should already be there, just give it a click.
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=2688&submit.x=58&submit.y=1
Jan 03, 2008 | Casio DW9051B-1V Wrist Watch
T-mobile dash multiple alarms
The solution is a follows; If you have any legit alarms already set, disable them before proceeding
1) As soon as the unwanted alarm goes off , look at what time your phone says it is and make a note of it. (if you know EXACTLY what time it goes off at, then go to the next step)
2) Goto Start -> Clock & Alarm -> Alarm
3) Set the alarm time for the exact time from step #1. Set alarm to On.
4) Click Done, done, and done
5) Goto Start -> Clock & Alarm -> Alarm
6) Change the alarm to Off.
7) Click Done, done, and done
That's it, the alarm should now be disabled for this unwanted alarm, if you have multiple unwanted alarms, repeat this procedure for each.
Dec 11, 2007 | T-Mobile Dash Smartphone
Issues with samsung u340
on the options menu for the alarms instead of clicking to reset a single alarm you must reset all alarms at once.. worked on mine anyway.. wish you luck
Aug 02, 2007 | Samsung SCH-u340 Cellular Phone
Palm Tungsten T5 - Multilingual Handheld Logo
429 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
