Computers & Internet Logo
Posted on Jul 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When hooking up my 120 Gb external hard drive to my laptop, I noticed there was an additional power supply required, DC by the look of it. I can't seem to find the correct size of outlet, or even an adapter. Could you tell me what the exact power cord voltage would be & possibly direct me to a major chain or website where I might buy a new one?
Anonymous
Level 2:
Genius:
  • Expert 1,325 Answers
  • Posted on Jul 16, 2011
Anonymous
Expert
Level 2:
Genius:
Answers
1325
Questions
Helped
344207
Points
292
Hi
The SimpleTech SimpleDrive Portable external hard drive features a USB 2.0 interface for speed and plug-and-play connectivity. The hard drive is USB -powered, so no extra power supply is needed.
please send me 4 thumbs up
What voltage is required for the power inlet port or is the USB cable enough?
The 2.5 inch external drive (laptop drive) does not require separate power supply because USB cable can supply enough power for this drive. The 3.5 inch external drive (desktop hard drive) requires separate power supply and it depends on the model.
I have a simpletech 120 GB external USB hard drive with NO power supply. Do you know what the power rating is (ac or dc, how many volts, amperage...) or where I can get a new power supply for it? -Thanks
12VDC, 1.5A external power adapter Well that is what this page says, it's not your 120GB drive but unsure if it's no the same model maybe. However all external HDD that need a power supply should be needing 12 volts, as they are just internal drives mounted in a shell and some simple circuitry to power and connect it.
My drive want power up when plugged into my laptop.
The 1TB My Book Drive usually requires an additional external power supply and does NOT power up from the USB cable alone. Only the small 2.5" drives requires no addition power supply.
1helpful
I have a maxtor 120GB external hard drive but no power supply. How do I get a replacement? I tried a switchable power adapter from a local hardware shop and although I set the voltage to 12v it lights up...
Hi Dave.
The problem you are having is the adaptor you tried is the right voltage but not the correct ampage. You require a 12v dc adapter with a rating of at least 1-Amp. The switchable supply you purchased would be well under the required level, probably 400ma (milli-amp), in other words about half the needed amount. A cable modem power adapter would be sufficiant. If you have one, make sure it is the correct voltage and polarity, positive pole (+) usually the inner pin on the end of the connector. Hope this is of some help to you.
Lost or misplaced power supply for Beyond Micro Micro Model BMMDU2 External hard Drive. Need info on Wattage input. Please and Thanks if you're able to hrlp.
Well, looks like Beyond Mico web site has gone to the great Beyond.
From units I have been able to find online, it looks like the power supply is between 20 and 40 watts.
The hard drive unit itself should be able to supply you with the required DC input voltage (hopefully there is some kind of label on the enclosure).
You could try one of these or something similar. It comes with 6 interchangeable heads and has adjustable DC voltage. This is just one of many available.
http://www.amazon.com/Hosa-ACD477-100-240V-Voltage-Adaptor/dp/B000Z31G3M
I cannot guarentee any of these supplied heads will fit your particular drive (same with the dc voltage). But some local retailers often have these types of adapters and you might be able to determine what size you need by looking at one.
I have used DC units similar to these in the past when I have lost a power supply.
Hopefully with a minimum of effort you can get a working solution.
1helpful
Dear Sir/ Madam, I have TWO Western Digital USB
first of all , you are looking at the wrong voltages. The important voltage is the DC OUTPUT, which is the voltage the external harddrives use AND the polarity of the plug attached to the harddrive end of the cable.
if both the harddrives have say 12v dc output and both have the insignia of the center conductor being + (posative) then you can interchange them. and you CAN run a 9volt unit with 12volt DC power, but not the other way around.
Look at your power adaptors again for the OUTPUT and polarity.
should be a half-circle with lines depicting the polarity(+,-) of the center and sheild connections to the hard drives printed on both the harddrives and the power adaptors . This can also be tested with a dc volt meter while the adaptors are plugged into the wall.
DO NOT try to test the AC end while plugged in!!
Regards
1helpful
Yesterday I bought an STP-120 SIMA power inverter
you inverter was not fully charged because it requires a 110/220 v ac as specified in the manual; to charge it so it is impossible for the aircraft 15vdc to charge it
Lost power supply
I think you might find this link most useful, from the Seagate Community Forums.
http://forums.seagate.com/stx/board/message?board.id=onetouch&message.id=1973
In short, others have had great difficulty buying Maxtor replacement power adapters, however you can buy a generic 12V, 3A DC power supply for $15-20 from a number of sources. Confirm your actual power requirements by referring to the product label on the drive itself.
Hope it helps,
Mike
1helpful
Drivers
The only DRiver is already supplied with OS 2000pro & up as Firewire. Problem connecting is due to the Supplied Power Supply. Wattage is too low at 1.5. Try a higher Power Supply.
14helpful
2answers
Power supply details for Maxtor 500 gb, external hard drive and ? manual
The PSU for my Maxtor 500Gb 9NZ2A4-500 drive is 12V DC, 2A rating, 2.1mm "plug" with centre "hole" as positive.
Regards, kbsguru
Top SimpleTech Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Alexander
ExpressFiX
ExpressFiX
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
