Hi and welcome to FixYa, I am Kelly
Check to door switch at the top of the freezer door hinge (left) and make sure the switch is being actuated when the door is closed. If you have ice production and only the water in door is not working then the most likely failure is the inlet water valve solenoid for the water in door only. There are 2 solenoids. 1 for the ice maker and 1 for water in door. If the water in door solenoid has failed you will have ice production but no water in door. The only remedy is to replace the inlet water valve. The are not repairable. If both water in door AND the water in door functions have ceased the most likely suspect is the door switch.
Thanks for choosing FixYa,
Kelly
