Aremove the write protection first You will have to be the computer administrator to change
any values on any hard drive click start control panel user accounts you should see a box with the administrator and the
guest account if you have made one click on the administrator this may vary depending on which operating
system you have click start click to open on my computer you should see your
hard drive usually C: right click select properties there will be an array of
options select the security tab option then advanced make sure you have full
control in windows 7
If you are running a
Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.?
click start click on my
computer to open you should see your drive
another way
click start all programs
accessories open windows explorer click on my computer you should see your
drive click to open it also right click select send to desktop to make shortcut
computer you should see your 4 GB data it might be listed as a mass storage
device
right click then select
format
another way is to control panel administrive tools computer management
disk management right click on your 4GB datatraveller select format
hope this helps you
