Computers & Internet Logo
Posted on Jul 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The touch pad stopped working and the a small light on the touch pad turned on.
ebirux
Level 2:
  • Expert 103 Answers
  • Posted on Jul 15, 2011
ebirux
Expert
Level 2:
Answers
103
Questions
0
Helped
29797
Points
319
Just press the button near the touch pad or press fn + the key with a picture of a touch pad on it.
2answers
My touch pad is not working. There is an orange light on it.
I am really sorry to hear that your touch pad is not working. You mentioned that you see an orange light on it, where did you see it? is it on the top of your touch pad? if it's just on the top of your touch pad, all you have to do is just press the button right beside the orange light. Because the touch pad is being disable indicating the orange light, when you press the button you will see a blue light indicating that you enable the touch pad.
Thanks.
Hi, I'm using K40In. I can not use the touch-pad anymore. since I realized that, I've tried plenty ways to install the ELANTECH software.... but can not. plz reply me ASAP.
There should be a function key to enable/disable the touch-pad (Fn and one of the light blue keys usually "F" keys) try to look through the keys and see if you have the pad turnned off, if it was a windows update theat stopped it from working then you should be able to roll it back to a working order from a system restore point. Go under the start menu select accessories, system tools, system restore then select the restore point at which you remember the touch-pad still worked.
1helpful
HOW TO lock touch pad in my compaq cq62 laptop?
there is a light above your touch pad and a small button directly below the light. When it is white the touch pad is on. Turn it off and the light goes red.
2answers
The mouse touchpad,stopped working and now the mouse usb,has stopped working.
please chaeck the mouse pad lock mode or any light is glowing on top of the mouse touch pad?
Touch pad stopped working
Hello, you can try one of the below steps:
1) Check if you have small on/off button for touch pad, it should be near the touch pad.
2) Remove the battery and put it back and try.
3) Try uninstall and reinstall the driver for pointing device.
Please with your progress.
(We require your rating to improve our quality)
29helpful
4answers
Emachines e725 Touchpad Not Working
The eMachines E725 has a built in switch to toggle the touchpad on or off by the touch of a button. Look at the button to the left of the main power switch. You'll notice the icon looks like a hand touching a rectangle - or touchpad. if this button is lit up, the touchpad is turned off. simply press the button to toggle the touchpad back on. The light on the button should now be off.
It's that simple.
3helpful
HP Pavilion dv8000 - touch scroll pad won't work
at the top black rim around the touch pad, there is an orange light showing, press and have it show blue. It will work now.
Cheers.
Please rate this fixya.
1helpful
3answers
Touch pad does not work
If it stopped working after you dropped it, try this:
Hold the Zen in your hand, and with your thumb, press down on the face board as hard as you can. Use your other hand's finger to scroll up or down on the touch pad. Press down different areas of the face board until you find a spot that, when pressed, causes the touch pad to work. Then, using both of your thumbs, press that spot VERY hard until the touch pad works without pressing.
1helpful
Touchpad
When the touch pad stops working it's one of three things. 1- A driver glitch, unistall the touch pad drivers from the device manager, then reboot. The machine will find the touch pad and reinstall the drivers automatically. 2- The touch pad connector has worked loose. Take the palm rest with the touch pad off, disconnect the cable, clean the connectors, and reseat the cable firmly. 3- the touch pad has failed and will need to be replaced. The driver glitch is the most common, I believe that it should take care of the problem. Let me know.
Grand Canyon Tech
Grand Canyon Tech
