Zyxel P660HW-D1 Router Logo
Anonymous Posted on Jul 15, 2011
The options of the main page of router do not appears so I can not configure the router and cant change any thing
Computer hardware and networking support
Level 3:
  • Master 4,281 Answers
  • Posted on Jul 15, 2011
Master
Level 3:
Answers
4281
Questions
0
Helped
971717
Points
12566
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
2helpful
2answers
Reset password
The default password for the router's Web Configuration Manager is password. NETGEAR recommends that you change this password to a more secure password.
To change the administrator password: 1. On the main menu, under Maintenance, select Set Password to display the Set Password screen. 2. To change the password, first enter the old password, then enter the new password twice. 3. Click Apply.
Best of luck!
The options on the main page of the router do not appears so I can not configure the router
How are you accessing the router access page? Are you putting in 192.168.1.1 in the address bar?
2helpful
How do i set a password
Router's password could mean 2 things. First password for you to open router's configuration page or password for you to connect wireless to your router.
Configuration's password:
-Logon to your router configuration page
-Please to the TOOLS and ADMIN Tab. You there you can change the admin user name and password. If you do not have the user name and password, please check for the default user name and password on the router's manual. If default user name and password won't work reset the router. Press and hold down the reset button or pinhole on the back of the router for 10 seconds. Then re-enter user name and password again. It should work this time.
Wireless Security Password:
-Under SETUP and Wireless Settings tab you will get an option to change the wireless password
5helpful
How do I change the password on the Actiontec wireless router? (Not the WPA key, but the web interface password. I just want to change it from the default "password1")
  1. Open a Web browser. In the “Address” text box, type http://192.168.0., then press Enter on the keyboard.
  2. The Web Configurator’s “Main Menu” screen appears. Select Setup/Configuration.
  3. From the Setup/Configuration screen, select Admin Username/Password from the menu on the left side.
  4. The “Change Admin Username/Password” screen appears. Enter a new user name (optional) in the “New Username” text box, then a password in the “New Password” text box. Re-enter the password in the “Re-enter New Password” text box. Make sure to write the user name and password down and keep them in a secure location.
  5. Click Save and Restart at the bottom of the screen.
  6. The “Save and Restart” page appears. Click the Save and Restart button to save the settings changed in the Change Admin Username/Password screen.
  7. Once the Gateway has rebooted, the password is active.
You can also download a user manual from here, or - if you have any more questions - just come back here and leave a comment - I'm happy to help.
I am trying to bridge a belkin n router to a d-link router
ok
the simplest way is to find some alternatives, here as some suggestions
now if you do want to attempt your solution do a few things first
first you do need to go into the belkin router's configuration page you can do this by:
  1. Open a web browser on the computer.
  2. In the address bar of the web browser, type http://192.168.2.1
  3. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
or if you set up a password can't remember it do this first
http://en-us-support.belkin.com/app/answers/detail/a_id/48/kw/F5D8231-4/p/312/r_id/166
now.. you need to find out if both routers support bridging.. you need to look into both router's configuration page, I couldnt find you router's manual and you did not posted you dlink router's configuration.
if you do find bridging try the directions found here
post back if you have questions after reviewing each router's configuration.
now an alternative option is to
I cant connect to the net threw the router, wireless, or straight off the router. I have tryed to reset it no diffrent. The router connects and it shows im connected but im not ive been threw every thing i...
Check the setup page for the configuration of your Modem for an IP Passthrough option. It sounds like your router is not properly being sent an IP address from the modem.
Hope this helps.
1helpful
2answers
Cant connect to any internet page through linksys etherfast cable/dsl router
Check your windows network configuration. You may have to go through the wireless setup wizard by adding a connection. At least you know they recognize each other. There also may be a security code that is needed in the network setup in windows. right click on the network connection and look at properties. only change one thing at a time and document what changes you make.
Belkin router dont take ip
if your in vista, click on the network tab on the start menu, then it should show all of the devices connected to your network, if you see your router, left click it, there should be an option to view device webpage.
Top Zyxel Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
