Homelite Factory Reconditioned  26cc Gas-Powered MightyLite Hedge Trimmer  Logo
Posted on Jul 15, 2011
Homelite petrol Hedge trimmer. runs but getting slower and losing power. using fresh 40:1 oil to petrol. any ideas pleas/
4 Related Answers
Anonymous
  • 76 Answers
  • Posted on Jan 18, 2009
SOURCE: oil ratio
you can use a 40:1 mix if it smokes then cut it back to 32:1 but a little more oil is better than not enough so start with the 40:1
Anonymous
  • 11 Answers
  • Posted on May 19, 2009
SOURCE: Wont coil back into its housing, so trimmer wont start. Has compression though
Hi, this a cut&paste from elswhere but it applies to your problem:
how to repair a recoil spring: whats missing is this, you should always wgear eye protection when dealing with springs of any kind.
remember safty first. :)
Remove the recoil shroud and take a look at the assembly.
You might have a broken spring or just a rope that has slipped out of the reel.
The spring usually breaks at one of the end tabs. If so, you will need to get a replacement spring and carefully wind that in, before re-assembling the rope reel. You might wish to replace the rope also, if it shows signs
of wear.
You will need to remove the entire cooling shroud. There should be 4 bolts on the sides. You might need to remove the fuel tank also. Pre-wind the recoil reel by hand [about 6 turns, to set the spring tension] and clamp it with Vise-Grip pliers. Remove the old rope. Thread
the new rope through the shroud housing eyelet and to the reel hub. Let the reel re-wind itself until it is full. If there is not enough spring tension you can wind it a couple of turns more by slipping the rope around
between the reel and shroud. Re-clamp the reel. Cut the rope to length and thread it though the handle. At all knots, burn and melt the rope with a
lighter to prevent untying. Re-assemble.
(special thanks to "Micheal"the author)
preloved003
  • 28 Answers
  • Posted on Aug 06, 2009
SOURCE: Husquarna petrol hedge trimmer starting problem
it could be extremely flooded with way to much fuel. in the motor.take out the sparkplug turn the ignition switch OFF and pull the starter rope...if there is a lot of fuel blowing out of the cylinder...thats your problem.....buy a new sparkplug and try starting it with no choke and full throttle with the new sparkplug fitted....see how you go.....or its warn out and has no compression to fire up the fuel.....in this case ..its time to upgrade
Anonymous
  • 2468 Answers
  • Posted on Jun 14, 2010
SOURCE: Fuel Ratio
40:1 gas/oil mixture
Fuel Ratio What is the fuel Ratio for the Homelite HT -17 Hedge trimmer?
2 stroke tools generally run at 50:1
100ml of oil in 5L of petrol
1helpful
Homelite 25cc 2cycle trimmer.built in March of 1999. what is the proper oil to gas ratio?
If you use a synthetic 2-stroke oil, you can easily get by running a 40:1 ratio mix...that is 3.2oz oil/gallon of gas. A richer oil mix won't hurt either (say 20:1 (2X the oil of 40:1). I recommend synthetic always be used alongwith Stabil fuel treatment because after about 30 days, gas loses its volatility and begins to breakdown without it...causing fuel problems.
1helpful
Homelite 21" hedge trimmer. Won't start. Has spark, compression, fuel (used a little starter fluid), checker spark arrestor and muffler (clear). I haven't torn it down to check the Woodruff key but it ran...
Abell, put a little drop of petrol in the plug hole, replace plug and give it a pull. If it fires up for a moment, it is a fuel starvation problem. Check the carb, clean and make sure the nedel valve in the bottom of the carb is not sticking. Good luck!
5helpful
4helpful
2answers
What is the oil to gas ratio for a Homelite ST-155 trimmer?
40 to 1,,,40 parts petrol to 1 part oil,,,,1/2 oz oil to 1 pint or petrol
but iv all ways ran mine on 30 to 1 ok,,it smokes a little,,but if its smoking there is oil getting to the piston and bearings,,,so the engine will live a lot longer,,,my pall runs his on 20 to 1??? now that smokes!
but he's run it on this for 25 plus years??? and he gun's it to death,,
so il say no more!
2helpful
Homelite hedge trimmer , motor runs but blades do
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
5helpful
2helpful
HT-17 Hedge Trimmer Fuel Ratio?
I use 40:1 in mine always have works perfect 3.2oz of reputable 2 cycle oil to one gallon of fresh gas
try to find the oil that has fuel stabilizer already in it
6helpful
Oil ratio
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
