Yes, you can drill them with most any hole saw...just make sure to only use the pilot bit when drilling the pilot hole and then place the hole saw on after the pilot hole is drilled...
Do not apply much pressure to the bit... only enough to give a bit of a cut from the bit as you are drilling the hole.
heatman101
Put on rubber gloves. Spray the sink with a nonabrasive commercial kitchen cleaner, covering all surfaces of the sink with the spray.
Dampen a sponge in warm water. Wipe the sponge over the sink, scrubbing at any visible dirt.
Rinse the sink with warm water and then dry it with a clean towel.
Fill the sink with warm water and add 1 tsp. of chlorine bleach per gallon of water, once a month. This will sanitize the sink, and is recommended by Thermocast. Let the bleach-water mixture remain in the sink for 15 minutes, then drain the sink. Rinse.
Apply liquid automotive polish to a clean, soft cloth. Wipe the cloth over the sink to remove any scratches that may have occurred. Buff the sink using a circular motion. Rinse.
