Impact 3/4" Dr. Heavy - Duty Air Wrench Logo
Anonymous Posted on Aug 27, 2008
Wrench Support what accessories should I use/need?
Anonymous
Level 3:
President:
  • Master 2,712 Answers
  • Posted on Aug 27, 2008
Anonymous
Master
Level 3:
President:
Answers
2712
Questions
Helped
723282
Points
8771
An impact wrench also requires a few special accessories. An air-powered impact wrench runs off of an air compressor with a tank – the air compressor should have at least a 10 gallon tank and be able to generate at least 3hp. Also, an impact wrench requires special sockets that are designed to withstand the high torque applied by the wrench.
Metric conversion charts
Closest is 16 but may not fit exactly. Best to use a 3/4 wrench on a 3/4 bolt and a 16 mm on a 16mm
Belt replace instructions
The accessory drive belt is a serpentine type belt that is driven by the crankshaft pulley
The belt drives the A/C compressor , alternator , power steering pump and water pump . Belt tension is maintained by an automatic belt tensioner .
Removal:
1. Using a wrench, rotate accessory drive belt tensioner counterclockwise until accessory drive belt can be removed from pulleys .
2. Remove accessory drive belt .
Installation:
NOTE: When installing drive belt on the pulleys, make sure that belt is properly routed and all V-grooves make proper contact with pulley grooves.
1. Install the accessory drive belt around all the pulleys except for the alternator pulley.
2. Using a wrench, rotate accessory drive belt tensioner counterclockwise until accessory drive belt can be installed on the alternator pulley .Release spring tension onto accessory drive belt .
What size allen wrench does it take to remove front brake pads on a merz benz ml350 2007
You will need an odd size metric allen key wrench. I say this because the Asian sizes run 8-10-12-14-17-19-21mm. European sizes run 9-11-13-15-16-18 -22 for some unfathomable reason. A good tool supply shop will have both sizes for you.
How do you replace an alternater in a 1997 dodge ram 150 truck
You will be needigng the below;
  • New alternator
  • Socket wrench set
  • Torque wrench
  • Determine which alternator your Dodge Ram will need. You'll want to be sure the new alternator is compatible with your Ram's engine. A Dodge Ram made after 2001 may be equipped with a 3.7 L, 4.7 L, 5.7 L Hemi V8, 5.9 L Magnum V8, 5.9 L Cummins diesel, 6.7 L Cummins diesel, 8.0 L Magnum or 8.3 L Viper engine.
    Disconnect the negative battery cable with a socket wrench. Remove the accessory drive belt and disconnect the wiring harness from the alternator. You will also need to remove the support bracket with a socket wrench for 3.7 L, 4.7 L and 5.7 L engines.
    Take the mounting bolts off of the alternator with a socket wrench and remove the alternator assembly.
    Install the new alternator assembly. If you have a 3.7 L engine, tighten the horizontal bolts to 42 foot pounds and the vertical bolt to 29 foot pounds with a torque wrench. Torque the long horizontal bolt and vertical bolt to 41 foot pounds and the short horizontal bolt to 55 foot pounds for a 4.7 L engine. Torque the mounting bolts to 30 foot pounds for all other engines.
    Connect the wiring harness to the alternator, install the accessory drive belt and connect the negative battery cable.
    I hope this helps.
    Good luck.
    Looking for any extra help for installing the serpentine belt on my 2003 pontiac vibe....is there going to be any major trouble spots that we should know about?
    Hope this helps!!!
    2003–05 1ZZ-FE Engine & 2003 2ZZ-GE Engine
    1. Disconnect the negative battery cable.
    2. Use a wrench and rotate the belt tensioner clockwise.
    1. With pressure applied to the wrench, and tension relieved from the drive belt, remove the accessory drive belt.
    To install:
    1. Raise and safely support the vehicle.
    2. Remove the right side lower engine splash shield.
    3. Properly route and install the accessory drive belt onto the drive pulleys.
    4. Use a wrench and rotate the belt tensioner clockwise.
    5. With pressure applied to the wrench, install the accessory drive belt.
    6. With the accessory drive belt installed properly, release the belt tensioner.
    7. Install the right side lower engine splash shield.
    8. Connect the negative battery cable. Tighten the battery cable bolt to 11 ft. lbs. (15 Nm).
    10helpful
    Need diagram for serpentine belt
    2004 SUZUKI FORENZA - L4 2.0L 2000cc GAS FI N
    Adjustment
    The belt is automatically adjusted by the auto tensioner.
    Drive Belt Routings
    Fig. Accessory drive belt routing-2.0L engine
    Removal & Installation
    1. Remove the air filter housing assembly bolts and the air intake tube.
    2. Remove the air filter housing assembly from the vehicle.
    3. Use a wrench to turn the tensioner bolt clockwise, compressing the tensioner, and releasing the tension on the serpentine accessory drive belt.
    4. Remove the serpentine accessory drive belt.
    To install:
    1. Use a wrench to turn the tensioner bolt clockwise, compressing the tensioner, and releasing the tension on the serpentine accessory drive belt.
    2. With the wrench in place on the tensioner bolt, loop the serpentine accessory drive belt loosely over the pulleys.
    3. Slip the belt over the tensioner.
    4. Remove the wrench from the tensioner bolt and the belt will tighten itself.
    5. Install the air filter housing assembly into the vehicle.
    6. Install the air intake tube and the air filter housing assembly bolts.
    7. Tighten the air filter housing assembly bolts to 53 inch lbs. and nm
    I really hope helped with this. remember rated this help. Good luck.
    21helpful
    How to replace serpentine belt on toyota matrix 2003
    2003–06 1zz-FE Engine & 2003 2zz-FE Engine
    Use a wrench and rotate the belt tensioner clockwise—2003–06 1ZZ-FE engine and 2003 2ZZ-FE engine
    To install:
    1. With pressure applied to the wrench, install the accessory drive belt.
    2. With the accessory drive belt installed properly, release the belt tensioner.
    3. Install the right side lower engine splash shield.
    4. Connect the negative battery cable. Tighten the battery cable bolt to 11 ft. lbs. (15 Nm).
    Pd -m424 cant get pedals off bike? do i need to use allen key as well as spanner
    No, you do not need to use both. In fact, you should never use a spanner wrench to remove your pedals or anything requiring large amounts of torque. For removing your pedals you should be using an pedal wrench or if the pedals are not very tight the allen wrench. A basic pedal wrench like the Park PW-5 is inexpensive and does a great job. Also remember that the non-drive side(left) is reverse threads, meaning both sides come off by unthreading to the rear of the bike.
    Hope this helps. Thank you
    Top Impact Air Tools & Compressors Experts
    ADMIN Andrew
    ADMIN Andrew
    Kardoc
    Steve Pack
    Steve Pack
    Are you an Impact Air Tool and Compressor Expert? Answer questions, earn points and help others
