I developed the same problem "unable to clean 46" on my brother dcp -330c printer.. after taking to a maintenance guy... he told me to remove my ink absorption pads and wash them out with water and leave to dry then once dry replace back in..
Download the driver/firmware from here
Brother-All-In-one-drivers
or you can use you cd/dvd, but you need to install it using the "Add New Printer Wizard", otherwise i don't think it would be possible. Good luck
Thanks for using FixYa.
Usually there is more than one cartridge empty when you receive this kind of problem. Try opening the top cover and check if the display changes - it should change to specify one (or more) of the color cartridges as empty. That one(s) should be changed too.
How to vote you're expert & also how to repost more questions for same problem or answer expert's questions. Enter FixYa.com site. Sign in to your FixYa account. Locate My Profile on our FixYa's homepage. Under My Problem locate your problem and click on it. Under the solution given by the expert, choose. Click om the color.
This COULD BE that there is some paper stuck in the dcp. Open cover and try to see if there is some paper left in the machine. I ve noticed, that -seeing from behind!- on the right side paperpieces are stuck and disturb the disk (foil) which give the printer info what to do.
Open cover and try to look into the edges (seeing from the front: its the left side -where the modell name is printed)
In some cases this means that the purgecamshaft is defective.
