I have not get display due to mother board no access the RAM. and i have check the mother board without install RAM and i did not get any beep/sound plz tell me what is the problem and how i can solved this
Re: I have not get display due to mother board no access...
This motherboard has an on-board video card and it uses shared RAM. The video uses part of the main RAM and if there is no RAM modules installed then you will not get any display or POST beep codes.
OPEN UR CPU AND OUT UR RAM FROM MOTHERBOARD AND START UR PC WITHOUT RAM IS IT BEEP OR NOT IF IT BEEP THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC IS IT OK
IF NOT THEN PICOUT BATERY CELL 2032 FROM MOTHER BOARD AND THEN START UR PC
IS IT BEEP WITHOUT RAM AND CELL IF YES THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC
IF IT IS OK THEN CHANGE UR BATTERY WITH NEW ONE
IF UR PC BEEP WITHOUT RAM BUT NO DISPLAY WITH RAM THEN CHANGE UR RAM WITH NEW ONE.
Are these computers all emachines? this board is normally used in the emachine range of computers and have a problem with the architecture
Call me ? chris
http://www.motherboardsrus.net
07926-106150
this is normal No-Ram. No-Beep.
The ram is all part of the bios analysis beep codes.
install memory, and setup the board to the manufacturers specification.
1 beep at post is normal on many bioses.
Mike @ compurepair.
MODEL NO.--INTEL 845 GVRS. problem is --- power led is on but no display and no beep sound. SMBS, RAM ,, PROCESSER, & HD Are all ok. Pls. tell me how can i slove my problem?
hi,
The beep test is notrmally done with the small speaker attached to the computer internally,
there could be a problem with the RAM installation check the RAM compatablity with the mother board, give me further details of the make and model of the mother board and RAM ,
i will try to help you.
