Most likely the CMOS (Bios battery), which is a small silver coin shaped battery on the motherboard needs changing. This maintains the correct time when the laptop is switched off. They last for up to 3 years then need replacing. (example in picture)
http://cgi.ebay.co.uk/CMOS-RTC-Battery-Toshiba-Satellite-A105-Series-/270751984156?pt=US_Batteries&hash=item3f0a136a1c
Be careful in changing the battery, If you have not done this before, refer to a computer repair shop.
I couldn't figure out how to change the time zone because I didn't have the manual. Here's how to change time zone:
1. On top of clock you hold down time zone button
2. Push the up or down button to change the time zone. There are 7 time zones. The clock is set at zone 2 -Eastern Standard time. My zone is 3 -Central Time - I then had to manually set the correct time -(I'm not sure why but I did that) To test if the time zone worked properly I switched the time zones and the time on the clock adjusted automatically to the associated time for that area. I, of course, moved it back to zone 3 and the correct time for central time was displayed. I am waiting to see if the time properly adjust when time the DST changes. Also, for the manual: http://www.emersonradio.com/owner_manuals_list.php?ID=157
This is the manufacturers website (Emerson) for the EZ Set clock radio. Hope this helps.
