Shimano 105 HB-5500 Logo
Posted on Jul 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My rear small sprocket hits the spokes on the rear wheel, how can I adjust it?
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Jul 13, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2767331
Points
24828
A sprocket is a gear on the cluster. I think you mean the derailleur pulley.
http://www.parktool.com/blog/repair-help/rear-derailler-adjustments-derailleur
Chain adjustment
Just a guess, but beings you didn't give YEAR/MAKE/MODEL, that's all I can do.
IF it's the rear drive chain you're talking about (as opposed to the primary chain), get rear wheel off the ground.
With bike in neutral, rotate rear wheel until you find the tightest spot of the chain in the middle between the rear sprocket and the transmission sprocket.
Loosen axle nut, adjust rear axle adjusters evenly until slack is within spec.
Rotate rear wheel in normal direction of travel and see that chain is tracking true on sprocket. If not,adjust as needed with axle adjusters.
IF mechanical rear brake (instead of hydraulic rear brake), adjust brake.
Oct 16, 2013 • Motorcycles
What is the axle torque settings on the front an rear axle bolts on a 2007 ktm 250 xc?
Thank you for contacting FixYa with your inquiry.
I have compiled a list of all the useful KTM torque setting that apply to your bike.
KTM Torque settings
  1. Collar screw, front wheel spindle Front axle nut 40Nm 30ft lbs
  2. Brake Caliper front Brake Caliper front Loctite 243 2 19ft lbs
  3. Brake Disk, front Brake disk front Loctite 243 1 11ft lbs
  4. Brake Disk, rear Brake disk rear Loctite 243 1 11ft lbs
  5. Clamping screws, upper fork bridge Top triple clamp 20Nm 15ft lbs
  6. Clamping screws, lower fork bridge Bottom triple clamp 15Nm 11ft lbs
  7. Clamping screws, fork stubs Front axle pinch bolts 10Nm 7ft lbs
  8. Collar nut, rear wheel spindle Rear axle nut 80Nm 59ft lbs
  9. Hex nut swingarm bolt Swingarm nut 100Nm 74ft lbs
  10. Hex collar screw handlebar clamp Upper handlebar clamps 20Nm 15ft lbs
  11. Allen head screw handlebar support Lower handlebar clamps Loctite 243 4 30ft lbs
  12. Shock absorber top Shock absorber top bolt 60Nm 44ft lbs
  13. Shock absorber bottom Shock absorber botton bolt 60Nm 44ft lbs
  14. Sprocket screws Rear sprocket bolts Loctite 243 3 25ft lbs
  15. Ball joint for push rod Rear brake pedal pivot Loctite 243 1 7ft lbs
  16. Engine mounting bolts Engine mounting bolts 45Nm 33ft lbs
  17. Engine brace Engine brace 33Nm 24ft lbs
  18. Screw adjusting ring spring preload Shock preload collar bolt 8Nm 6ft lbs
  19. Spoke nipple Spokes 5Nm 4ft lbs
  20. Other Screws on chassis M6 10Nm 7ft lbs
  21. M8 25Nm 19ft lbs
  22. M10 45Nm 33ft lbs
  23. Other collar nutes on chassis M6 15Nm 11ft lbs
  24. M8 30Nm 22ft lbs
  25. M10 50Nm 37ft lbs
  26. Front Sprocket 44ft lbs
Let us know if we can provide further assistance.
Best regards,
TF
2helpful
I just god a new tire, tube, rim and spokes. Except i dont know how to install the spokes! How do i install spokes through the holes and to the rim? What is the correct order to put them in? What direction...
Thank you for the inquiry.
This is one of those projects in life that best requires special tools (Spoke Jig) and a lot of patience. I also recommend a couple of good quality spoke wrenches. The one that comes with your tool kit usually is for general emergency spoke tightening and minimal maintenance. Even at the shops there is not to many people that know how to do this well. It's time consuming and shop labor is expensive.
That being said here goes:
To get started you will need to know a couple of things:
  1. Spoke lacing pattern
  2. Rear sprocket/hub alignment position. (Chain must run true from front primary sprocket) this applies only if this is a rear wheel.
I've posted a link to some helpful pictures of wheel lacing on various bikes to give you a few tips and pointers. http://www.rcycle.com/wheellacing.html
Look at the spoke pattern on your other wheel to determine the direction to push the spokes through and determine the spacing pattern for the short or long spokes.
1) Lay the hub flat on a bench and install the spokes loosely in correct pattern. 2) Lay the rim over the spokes and push them through. Spoke direction corresponds to the receiving angle on the rim. Important to get started correctly than alternate. 3) Thumb tighten a couple of the nuts/ferrels loosely to hold rim in position. 4) Tighten nuts according to get the hub centered as best as possible (just to temporarily hold) 5) You can build a fixture with a couple of 2 x 4s as shown in the illustration or carefully clamp the bikes axel in a vice, not to damage the threads or pinch the axel nut.Horizontal position. 6) You will need to clamp a coat hanger or a heavy piece of wire to something solidly fixed to act as a reference guide. 7) Tighten spokes first for correct up/down centering then for left/right centering. 8) UP and Down: Position your gauge wire close to the top/front of the rim and rotate. Finger tighten and loosen the spoke nuts until you get the wheel running true for up/down motion. Keep going around and redoing until you get it as perfect as you can finger tight only. 9) Move you wire gauge to the side of the rim and repeat process. The front rim has a disc brake position to align for (not to critical) and the rear rim has a critical sprocket position to maintain. You will have to measure the sprocket offset to get it correct. Chain must run true. 10) Spin the rim on the axel for reference and Keep going around and tightening and loosening the spokes until you get the side alignment running true. May take a while and many spins. 11) Once you get the rim running true for both wobble and run out you are ready to slowly start tightening the spoke nuts with your spoke wrench's. Take you time and keep tightening in tiny amounts until you get tight and true. Tap the spokes as you go and listen for tension. 12) When you tap if you get a dull thunk - it's a little loose. If you get a ringing musical string sound you know you are tight and/or close depending on the amount of ring. Take your time.
Before you mount the tire be sure you mount the rim on the bike and run the axel in place to final check for front brake rotor alignment or real sprocket alignment. You may have to adjust.
I have always wrapped duct tape in the V-slot to hold the nuts and prevent spokes from coming up and puncturing the tube. Go around several times. Just maintain the groove so you can still have room to place the tire bead in to stretch for mounting.
Best wishes and good luck from a fellow biker/racer.
TF
I would like advice on adjusting the rear derailleurs on my Campag Record long cage set. I am very much an amateur, and am not sure which screw/nut to turn and by how much. Thank you.
ok...there are usually 2 screws,one above the other.The top screw normally adjusts the deraileur so that the deraileur does not touch the spokes.the bottom screw usually adjusts the derailer so that it does not go past the smallest sprocket.One way to adjust eg(incase you have clicking sounds as you pedal) is to put the deraileur into the smallest sprocket at the back end.Flip the bike upside down so it sits on the seat and handlebars.Now get right behind the deraileur and see if the deraileur is in line with the smallest sprocket.If it is not in line,then slowly pedal the bike and adjust the screw inwards until you hear no more clicking.If you cannot get into the smallest sprocket,then,turn the screw outwards while still turning the pedals.The deraileur will slowly move outwards until it jumps into the small sprocket and no clicking sound .Vice versa for the top screw.good luck.let me no how you get on
3helpful
2answers
Drive pulley bolt torque
I am assuming you're talking about the rear sprocket mounting bolts on the rear wheel. Laced (spoked) wheel - 45-55 foot pounds. Cast wheel, 55-65 foot pounds.
1helpful
My son just bought a 26" Huffy Jolt mountain bike. The rear sprockets spin freely when the pedals are cranked either forward or backward - - that is, there is no coupling to the rear wheel. What can I...
The plastic is to stop the chain from touching the spokes, it cannot cause this problem, either the chain is not on a sprocket correctly or the rear cluster(sprockets) is not working.
Some spray lube may help, but if it is new, take it back to the shop.
1helpful
I just replaced my offroad tires on my bike with road tires. Now I have a small, but noticeable, vibration in the pedals when I ride. Is this a derailleur issue?
It could be a d-rail, but also could be spokes, chain rub, wheel hitting a brake pad, tire clearance at frame, bearings.
Put your bike upside down so you can turn the pedals while you check for where this may be coming from.
Take your time... these noises can "telegraph' thru the frame and fool you so look for visible signs, use a little chain lube, oil , etc and you'll be able to pin point your noise.
I had an issue on my high end road bike.. a clicking while pedaling uphill...very annoying... turned out to be the added pressure caused the rear wheel spokes to click at the crossover point... a little heat shrink tubing did a nice alteration without a spoke pressure increase... So look around , start eliminating the possiblitites and you'll find it!
1helpful
Remove 5 speed sprocket on 26''rear wheel
hi
you need a tool called a rear sproket puller, best to take it to a bike shop they will only charge you a pound to take it off there and then in seconds,
Mar 23, 2009 • Cycling
3helpful
2answers
How to adjust front and rear shifting gear
there are two small screws located on the derailleur. Hi/Low
http://www.parktool.com/repair/
this might help too
Top Shimano Cycling Experts
Paul Bade
john h
ADMIN Andrew
ADMIN Andrew
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
