I recently cleared off the sd card, but whenever I try to record I get the card full error. There are no projects or mp3 files on the device. When I check on the computer via USB it also shows no files, but when I view the properties it shows that all the memory is being taken up. How can this be when there are in fact no files on the recorder?
I had the same issue, and ended up solving it after trying many different things. So first you put the card in your reader, right click, and hit "format...". It should ask you if it's ok to erase everything. Say yes.
Then put the card in the recorder, and it should say "Unformatted". Hit Utility and TR4 to Initialize. That should do the trick. Hope that helps!
Menu > sd card > format
i have the same problem
go to menu > sd card > format
