Hi 2 Press the PLAY [UP]or STOP [DOWN] button to select INITIAL 3Press the PLAY [UP] or STOP [DOWN] button to select CLOCK, 4Press the PLAY [UP] or STOP {DOWN] button repeatedly to set the TIME. Every time you press the PLAY [UP] or STOP [DOWN] button, the time changes in one-minute increments. If you press and hold the PLAY {UP] or STOP [DOWN]9 button, the time changes in 30-minute 5Press the PLAY [UP] or STOP [DOWN] button repeatedly to set the DATE (month and day). Every time you press the PLAY [UP] or STOP [DOWN] button, the day changes in one-day increments. If you press and hold the PLAY [UP] or STOP [DOWN] button, the day changes in 15-day increments. When the month and day are correct, press the FF /OK 6Press the PLAY [UP] or STOP [DOWN] button repeatedly to set the YEAR. When the year is correct, press the FF /OK 7Press the FF /OK button once again to skip "AUTO CLOCK" and go to "D.S.T." (Daylight Savings Time). Press the PLAY [UP] or STOP [DOWN] button to set D.S.T. to ON or OFF. If AUTO CLOCK is OFF, you may set D.S.T. to ON or
To set the clock:
Manual Clock Setting
1Press the VCR button, then press the MENU button.
SET UP, then press the FF /OK button.
increments
button
button. The day of the week will appear automatically
OFF only
8Press the EXIT/STATUS button
