USB drives can be write-protected by modifying the
StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to
open the find dialogue box and type "usb device" or
"driverdesc" to open usb mass storage device or type "usb mass
storage device" in the search windows. And right click on it and delete.
This will set the policy value to 0. then insert your usb device. It will work
fine.
# Remember: do not delete any unknow files in the registry as this will make
some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps you
Scan your USB by an updated anti virus it might b attacked by a virus.
Turn on your computer and plug in the drive after your operating system has loaded.
Open "My Computer" and search the list of drives until you find your USB drive letter.
Right-click on the name and click "Properties." Once the options have loaded, go through the tabs until you see the option to remove write protection. If this does not work, go to the next step.
Visit the company website for your USB drive. Go to the help or support section and search for "write protection."
Click on the download section and search for "write protection software remover." Download the program and install it on your computer.
Open the software program. Go to "Option" and click "Remove Write Protection" to unlock your USB drive.
