SOURCE: Philips 20PF4121 LCD tv no picture but flashing error codes
I had exactly the same problem When the TV was switched on all I could
see was a flashing green light. After cheching the TV internals and not
seeing a problem including the power supply unit which looked and
checked normal. Here is what I did to get M TV working again.
Disconnect it from the power supply. Hold down all the buttons
simultaneously i.e. the on/off, the volume, the programme, menu
buttons, all of them simultaneously and Plug it into the power supply
again.
Lo and behold My TV jumped back into life after an absence of about 4 weeks.
Try it yourself exactly as above.
Best of luck.
Irishfreethinker
SOURCE: MY NAME IS PHILIP I
Hi
Thanks for using FixYa. If the TV isn't turning itself on then the fault protection circuit has detected a fault and has turned down the TV. The blinking indicates a fault. You'll need to check various things to find an answer which part is bad. Please check these---
1. Check for signal cables at the back and also try unplugging the TV for 8-10 hours to reset it.
2. Swollen /bulged capacitors on the power supply board-- This happens due to overheating of capacitors.
3. If the capacitors are fine then you'll need to check for connectors on all the boards and also the fans if they are working fine.
4. Make sure the lamp connections are fine and ballast is not burnt.
Note-- Please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in OFF condition, so please be careful.
Try to reset the TV by unplugging it for 6-8 hours.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
SOURCE: Phillips Flat TV Model 20pf4121\105 (Flashing green led)
electrolitic capacitors 1000mf /10 v in pover unit
SOURCE: philips 50pf9631d/37 no picture sound. Red light flashing
hey crs246, I have the same exact problem with my philips tv same model. Have you gotten any help that you can share with me. Any help would be appreciated.
