Olympus Camedia C-60 Zoom Digital Camera Logo
A
Anonymous Posted on Sep 06, 2005
How can I change the Resolution?
I was presented an Olympus C-60 Zoom by my son last month. I have understood majority of its functions by studying the User Manual but still can’t pick up some of them. For example : My 32MB Chip exhausted after taking 0nly 25 snaps which I think is due to high resolution (Pre-set to 2816x2112). I remember I was told that I can take up to 56 snaps with this chip. Probably this can be achieved by lowering the resolution size. I don’t know how to do it and could not find it in the manual. As the local distributor is quite far away from here, can someone please give me step by step guidance in this respect?
Anonymous
Level 3:
Master:
  • Master 852 Answers
  • Posted on Sep 06, 2005
Anonymous
Master
Level 3:
Master:
Answers
852
Questions
27
Helped
94921
Points
2489
Here are my instructions: 1. Turn the Camera On. (On the back you will see an OK button surrounded by 4 arrows.) 2. Press the OK button to bring up the menu. 3. Press the left arrow button 4. That should bring up a choice of: TIFF, SHQ, HQ, SQ1, SQ2 5. Use the up/down arrow buttons to move the cursor to SQ1 6. Then press the right arrow button That should bring up a choice of settings. 7. Use the up/down buttons to select a setting. I suggest you select 2048x1536 (which is 3 megapixels) 8. Then press the OK button. ..... I think you missed step 6. ..... Regarding TIFF. During step 5. It is possible that there is not enough room on the screen to see TIFF. Use the up/down buttons to move the cursor beyond the top and bottom items on the screen. You should find TIFF hiding there. ..... Regarding Resetting of settings. 1. Press the OK button 2. Press the right button 3. Use the Up/Down buttons to move the cursor to "Setup". 4. press the right button 5. You should see something called "All Reset" and it is probably set to "ON" 6. Move the cursor to All Reset. 7. Press the right button. 8. Move the cursor to Off 9. Press OK.
Anonymous
Level 3:
Master:
Anonymous
Master
Level 3:
Master:
Answers
852
Questions
27
Helped
94921
Points
2489
Olympus has its own way of showing the resolution settings. It is OK once you get used to it. Turn the Camera On. (On the back you will see an OK button surrounded by 4 arrows.) Press the OK button to bring up the menu. Press the left arrow button That should bring up a choice of: TIFF, SHQ, HQ, SQ1, SQ2 Use the up/down arrow buttons to move the cursor to SQ1 Then press the right arrow button That should bring up a choice of settings. Use the up/down buttons to select a setting. I suggest you select 2048x1536 (which is 3 megapixels) Then press the OK button. ................ You should think about getting a memory card with a greater capacity.
Need date stamp on pics taken with my Olympus Camedia c-60 camera. Cannot figure out how to make it work that way. Any ideas? Thx.
By default Olympus cameras do not print the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order or print reservation that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Camedia Master or Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
2answers
With the Olympus C 60 Zoom what is the most memory I can use on the picture card for this camera?
Hi!
The Olympus C-60 can support 16 to 512MB of xd Picture card.
I hope that helps.
Good luck and have a nice day!
2answers
How to change language setting from Japanese to english
I am going to have to say contact Olympus I have read all their manuals and notes on the camera and cant find nothing for language setting on it.
Record movies with sound
Yes. The Olympus C-60 Zoom Digital Camera can record movies in Quicktime Movie Mode, however it cannot record sound.
AC adapter
The D-7AC AC Adapter is designed for the Olympus C-60 Zoom Digital Camera. It outputs 4.8 Volts at 2 Amps. The stock number is 200850
Panorama feature
You can use the Panorama feature on the Olympus C-60 Zoom Digital Camera provided that you use an Olympus brand xD-Picture Card.
Difference between the D-460 and the D-450 Zoom digital camera
The D-490 Zoom shares the following features with the D-460 Zoom: •Olympus 5.4mm to 16.2mm (equiv. to 35mm to 105mm on a 35mm camera) lens: all-glass, 8 element, 6 groups, 2 aspherical lenses •Automatic TTL focus system •Macro mode allows the camera to auto focus as close as 8 inches •Automatic aperture selection: f2.8 to f8.0 wide, f4.4 to f12.6 tele •3x image magnification inspection mode •Panorama mode: Allows multiple pictures to be "stitched" together to create wide views •NTSC video output to TV •12-second self-timer •8MB SmartMedia card included •Built-in, pop-up intelligent flash: Auto low & backlight, red-eye reducing, off, fill-in, slow-sync •Automatic white balance control or 4 manual settings (daylight, cloudy, tungsten light, fluorescent light) •Automatic ISO sensitivity or manual selectable ISO settings •Uses 4 AA size batteries. AC Adapter is available as an optional accessory In addition, the D-490 Zoom has the following functions and features: •2.1 megapixel resolution (1600 x 1200) •Sequence mode - up to 5 shots in HQ and up to 45 shots in SQ mode (1.3fps) •Motion picture mode - up to 60 seconds of QuickTime movie (.mov) format (w/o audio)
Difference between the D-460 Zoom and the D-490 Zoom digital camera
Battery
Olympus Ni-MH batteries will last approximately 60 to 80 images and can be recharged about 500 times. The Olympus CR-V3 long-life lithium batteries provide power up to 2 times that of Ni-MH batteries. The CR-V3 long-life lithium batteries are NOT rechargeable.
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
