SOURCE: Gigabyte GA-945GZM-S2 motherboard I am getting no
PCI express card should do the trick for you
SOURCE: Problem for Gigabyte 945GZM-S2 Motherboard
HI,
There is only one memory stick that that board will support that is a 2gb chip. You can reveiw all the tested memory HERE, to see what will work prior to buying.
Good Luck,
Mark
SOURCE: enable to boot bootable usb drive,ga-945gzm-s2 motherboard
reset your bios inside your pc its a big watch battery take it out for 10 15 min then put back it if that does not work take out the battery again and if you see neer your battery was ther should be a small jumper its usually black and its plugged in your board it also should have 3 pins to plug it in when you take it out plug it in the next 2 pins (the miffle one will plug in aswell then put it back in the first pins again put battery back in an try to boot it should work...
SOURCE: i want the mother board lan ethernet driver of
You can download the drivers from Gigabyte WEB support site. Please click on this link and select your model motherboard and drivers you require :-
http://www.gigabyte.com.tw/support-downloads/support-downloads.aspx
SOURCE: help me find driver for GIGABYTE GA-945GZM-S2
You can download the drivers from Gigabyte WEB support site, select your model motherboard to download :-
