SOURCE: technics 1200sl pitch control
There seems to be 2 issues with this unit. Usually when the platter speeds up very quickly, one of the IC (integrated circuits) are faulty and needs to be replaced. However, I've never seen the 33/45 lights come on in addition. So, perhaps the issue started with faulty 33/45 switches, and it then caused a short to one of the IC's.
This will have to be professionally serviced, as it is not an easy fix. There are various circuits on the main board which control the drive, so it's a matter of diagnosing which is the culprit. The 33/45 switches will also need to be tested/replaced.
- TERMiNAL OPTiC
www.DJPROLAB.com
SOURCE: Technics SL-1200MK5 Pitch Control Problem
i got my turntables repaired by these guys www.technmics1210repair.co.uk
i did they made my setup work like new so im going to spread the word.
give them a shot
You can get a new pitch control here :-
http://stores.ebay.co.uk/methleykev
SOURCE: SL-1200 Turntable: I own two Technics SL-1200mk5 turntables. My probl...
Hi, could just be platter not fitted hard down on spindle. I suggest you remove the platter and place it upon a dead flat surface to check to see that the platter is flat. If it is flat refit to turntable ensuring it is hard down on the spindle. If bent discard and replace with new platter.Platters can be ordered for all model 1200/1210 from [email protected]
